Help, strange noise
Old May 16, 2006 | 10:18 AM
robes's Avatar
robes
Default Help, strange noise
My 2003 started making a loud squeeking noise (kinda like a kettle) yesterday. Happens all the time when I turn the wheel to the right and the sound is constant. Only happens part of the time when I turn left but it's the same sound both ways. Sound sometimes continues when I'm going straight after a turn. Any ideas on what is causing this? My boss said it could be my power steering pump. Does that sound right? What else could it be? Depending on what it is will it be covered under warranty? Thanks very much in advance for the help.
Old May 16, 2006 | 10:32 AM
Z_freak's Avatar
Z_freak
could be the pump or worse the rack and oinion, check your fluid level/cleanliness....when you pin the wheels to the stop does it make more noise ?? are you leaking anything ??
Old May 16, 2006 | 10:35 AM
NightRida's Avatar
NightRida
Of course it is covered under warranty! Assuming you still have some of your warranty left?
Peace!
Old May 16, 2006 | 10:36 AM
VO...'s Avatar
VO...
Administrator
Check the tightness of the belt. It could be loose. This'll cause squealing sometimes.
Old May 16, 2006 | 10:59 AM
imjdoggie's Avatar
imjdoggie
Could it be your brake pad warning???
Old May 16, 2006 | 12:10 PM
robes's Avatar
robes
No leaking of any kind at this point. Doesn't sound any worse when I turn the wheel all the way. Actually it's a higher pitched louder sound when I barely, and I mean barely, move the wheel. Also it only makes noise when I'm moving, if I'm stopped then there is no noise at all. Definitely not brake pad warning the sounds occurs with wheel use not brake use. What belt(s) should I check? I don't really ever work on cars myself.
Old May 16, 2006 | 01:52 PM
Z_freak's Avatar
Z_freak
if you do not have experience working on cars and it is under warranty then take it in....if it is not under warranty then take it in to get an estimate, you need to find out what it is....if you do throw a belt or something could cause more damage....not trying to scare you, just need to be safe, alsoif you have to have work done you want it as inexpensive as possible....unfortunately i cannot walk you through changing a belt on this post if you have never done anything like that before....and i know nobody else here would either, to risky....let the shop tell you what it is then post back what they say
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
