100+ Octane
Old Jun 24, 2006 | 04:40 AM
Kolia's Avatar
Kolia
Originally Posted by roast
WTF you talkin' 'bout willis.
100 octane will not damage your engine.
Agreed.
And it might improve performance in our Z. Unfortunately, we'd need to talk to the guy that programmed the ECU to learn if the mapping goes far enought to advance timing to take advantage of the high octane properties.
I've heard reports of high octane fuel leading to over heating exhaust valves and manifolds from improper combustion. If combustion is so slow (not enough advance) that it keeps on burning during the exhaust phase, it won't make the engine happy.
As a side note. With my Impreza 2.5RS (NA engine, built to run on regular), I'd get on average 50km more out of a tank of premium than regular.
It's a case by case thing. Dependent of the car, the driving style and environnement.
Old Jun 24, 2006 | 05:29 AM
roast's Avatar
roast
I guess it could depend on the conditions? With a stock Z I would think under conditions where the ECU pulls timing even with 91-93 octane that a higher octane would help prevent that from happening. Not so much that a super advanced timing could be run.
I didn't think the octane rating had anything to do with the rate of burn, just the amount of energy needed to initiate the burn??
Old Jun 25, 2006 | 05:03 PM
Kolia's Avatar
Kolia
I have a Bimmer friend who pluged his M3's cats with 2 tanks of race fuel...
Old Jun 25, 2006 | 05:11 PM
roast's Avatar
roast
It was most likely leaded then... they make unleaded 100octane that will not do that...
Old Jun 25, 2006 | 06:29 PM
Kolia's Avatar
Kolia
Unleaded
Old Jun 26, 2006 | 03:55 AM
bailey bill's Avatar
bailey bill
Originally Posted by Kolia
Agreed.
1) There is no advantage to using a higher octane rating than the manufacturer specifies. Octane rating is only a measure of knock resistance. Higher octane does NOT have greater energy content.
2) All commercially available automotive fuel is unleaded, regardless of octane rating. Higher octane has no effect on the cat, the O2 sensor, etc.
3) Actually lead was good for valves. It formed a deposit on the valve seat and the underside of the valve that both cushioned the valve, and impsroved sealing. This was one of the auto industries complaints when the US switched to unleaded, tht it would cause premature valve failure.
4) Higher octane is more resistant to ignition (Thats why it is knock resistant). And the burn rate is slightly slower.
bill
Old Jun 26, 2006 | 06:47 AM
GMZ's Avatar
GMZ
Originally Posted by USN HM 350Z
There is a gas station off of Mollison in El Cajon that sells 110 octane
The gas station that sells 100 octane is off I-8 (not sure of exit, but it is by the 15) There is a Home Depot if you keep driving past the Home Depot that gas station is there. It is an industrial type of gas station that normally caters to commercial vehicles. I have filled up there a few times, but the 110 off of mollison is only $6.00 a gallon so I used that mostly.
Ah yes I used to drive by it everytime I went to the mall. I miss San Diego! I wish Id get IA'd sometimes so I can drive my car over there to my Dad's house!
Old Jun 26, 2006 | 05:28 PM
Kolia's Avatar
Kolia
Originally Posted by bailey bill
1) There is no advantage to using a higher octane rating than the manufacturer specifies. Octane rating is only a measure of knock resistance. Higher octane does NOT have greater energy content.bill
I'd say that would be an advantage.
We're not even talking of the additives...
Old Jun 26, 2006 | 05:32 PM
bailey bill
"Are you tempted to buy a high octane gasoline for your car because you want to improve its performance? If so, take note: the recommended gasoline for most cars is regular octane. In fact, in most cases, using a higher octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage or run cleaner. Your best bet: listen to your owner's manual."
http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
bill
Old Jun 26, 2006 | 05:39 PM
Kolia's Avatar
Kolia
I’ll trust my own fuel consumption calculations thank you very much. Running premium in my Impreza, with my driving style, was cheaper than running regular. Period.
Now, if it’s stuff written on the web by people we don’t know that you need. Have a look at this:
http://www.toptiergas.com/
And put whatever you want in your car. It’s yours!
cbsuper
Aug 21, 2003 08:13 AM
Chebosto
Aug 6, 2003 06:31 AM
G I Love My Car
Jul 25, 2003 06:26 AM
oscarmayer00
Jul 17, 2003 05:26 PM
chahny
Apr 1, 2003 07:50 AM
