nismo shift knob buzzes at high rpms
Old Jul 17, 2006 | 09:06 PM
wesismyhero's Avatar
wesismyhero
Default nismo shift **** buzzes at high rpms
does anybody else have the carbon fiber nismo shift ****? i got mine for christmas and about a month ago the carbon fiber piece came loose and now spins around on its own. i don't mind that but if i tach it up to like 4k or higher it starts buzzing and i have to leave my hand on the shifter just to keep it quiet. anybody else got this problem?
Old Jul 17, 2006 | 09:10 PM
wesismyhero
yeah im almost to that point now.
Old Jul 17, 2006 | 09:34 PM
dkmesa350z's Avatar
dkmesa350z
I have the titanium one and the plastic ring on the shift boot sometimes rattles against it.
Old Jul 17, 2006 | 10:34 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
when you remove the factory shift ****, there is a nother metal colar ring thingy you have to remove as well... most leave it on... most of the time its this piece that is rattling...
where did you purchase your nismo ****. how long ago? you may beable to have it replaced under warranty if it is a problem with the actual **** and not what i described above...
Old Jul 17, 2006 | 11:08 PM
gsazabi's Avatar
gsazabi
May I suggest you ARC Titanium shift ****?
http://www.evasivemotorsports.com/me...ry_Code=ARC_SK
I have it and it's awesome.
There's only two shift ***** I will have for my Z and it's this and NISMO Ti GT shift ****.
Old Jul 18, 2006 | 01:20 PM
Jes-Z's Avatar
Jes-Z
my shift **** did that for a little bit, i ended up screwing in the shift **** so hard that it must of wedge the carbon fiber into the top of the ****. Try screwing it in to the point you start turning the shiftboot. It might work.
Old Jul 18, 2006 | 01:25 PM
Jason@Performance
Performance Nissan
This is what I am talking about... the piece highlighted in RED... It is usually stuck on there pretty good... so most people leave it on... and it comes loose later on and rattles... after that is removed, your **** wont rattle...
Old Jul 18, 2006 | 01:28 PM
20"makavelli's Avatar
20"makavelli
got mine on for about 3 months now no rattling yet
Old Jul 18, 2006 | 11:48 PM
wesismyhero
i got it for christmas so i'd say they won't take it back. i know it's the carbon piece cause i can just put my finger on it with little pressure and it stops.
Old Jul 19, 2006 | 12:09 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
You mean like the carbon fiber piece is no longer attached to the ****...and just kinda spins around on it's own? If so that's definitly a warranty thing.
Old Jul 19, 2006 | 04:39 AM
tropicalypso's Avatar
tropicalypso
loose carbon fiber aside, how do you like the shape and feel of that shift ****? I have the same one.
Old Jul 19, 2006 | 08:12 AM
Jason@Performance
Performance Nissan
its got a 1 year warranty from nissan... if you got it for christmas, and have the box... your local dealer might work with you on it...
you can try!
There is a form you need to fill out for it... If they have trouble finding it, I can fax it to you and you can show it to them and they will know what they need to do from there
Old Jul 19, 2006 | 07:45 PM
Escobar's Avatar
Escobar
I have just the factory **** but my shifter makes a small sound hardly audible but I am very picky and hear all the small stuff. I mostly hear it when Im driving on the freeway, if I push down on the shifter slightly, it goes away. Do you think that the collar your talking about Jason is the reason why?
Old Jul 19, 2006 | 08:27 PM
rockinbboy's Avatar
rockinbboy
There was a thread about the shifter vibrating at certain RPMs. Mine does this too..but I got a stock shifter. I imagine the problem to be the same and not because you got a different shifter.
Old Jul 19, 2006 | 10:15 PM
wesismyhero
yeah the carbon fiber piece actually came loose. i can spin it with my fingers.
Old Jul 19, 2006 | 10:52 PM
Santacruzslick
Veteran
Hmm...definitly a warranty issue.
sherm
Apr 11, 2020 05:21 PM
nanotech
Oct 2, 2015 05:02 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
