Do high flow cats void warranties?
Old Aug 19, 2006 | 10:33 AM
Everybodywildou's Avatar
Everybodywildou
Default Do high flow cats void warranties?
As the title states, do high flow cats void warranties?
Old Aug 19, 2006 | 11:50 AM
High-flow catalytic converters are a replacement for the OEM catalytic converters. I am not aware of any HFC failing a sniffer test. Why would they void the warranty?
Old Aug 19, 2006 | 12:05 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
No mods you do will void the warranty on your car...
But, if something goes wrong and the modification is directly the cause then it will be an issue...
if you have a problem with the emissions system (O2 Sensors, etc) then it will not be covered under warranty if high flow cats are installed...
if your aftermarket parts fail, they will not be covered under warranty from the dealer...
Old Aug 19, 2006 | 02:10 PM
Everybodywildou
DavidV and Jason. Cool to have two respected forum guys answer my questions. Thanks
Old Aug 19, 2006 | 03:18 PM
HighwaySpeed's Avatar
HighwaySpeed
Question
Originally Posted by davidv
Viagra comes in an aerosol can?
Old Aug 19, 2006 | 04:03 PM
ouch1011's Avatar
ouch1011
As was said, no mod will completely void your warranty. A dealer may refuse to work on your car based on a modification, but they cannot void your warranty.
On the other hand, if the cat convertor plugs, overheats, causes a huge exhaust restriction, causing really extreme exhaust temps and damages the engine, repairing the engine is probably not going to be covered by warranty since it was an aftermarket part that caused the failure.
Old Aug 19, 2006 | 05:21 PM
kcobean's Avatar
kcobean
Spend a few minutes and research the "Magnusson-Moss Act". This act protects car owners by allowing the use of replacement, non-OEM parts without fear of voiding a warranty that covers remaining OEM parts. As stated however, if the aftermarket part causes damage to, or the malfunction of an OEM part or system, you are on your own (unless you can find a mod-friendly dealership.)
Also, one note to at least be aware of: It is a violation of Federal Law to replace, remove, or modify a working OEM catalytic converter. (not that it stops anyone, including me).
Here is an entry from the page linked at the bottom of this post:
(6) When can I install an aftermarket converter?
Generally, there are only 3 situations when you can install an aftermarket converter.
They are:
(1) if the converter is missing from the vehicle when brought in for exhaust system repair; or
(2) if a State or local inspection program has determined the existing converter has been lead poisoned, damaged, or otherwise needs replacement; or
(3) if the vehicle is more than 5 years old or has more than 50,000 miles* (8 years/80,000 miles for 1995 and newer vehicles) and a legitimate need for replacement has been established and appropriately documented (e.g., a plugged converter or unrepairable exhaust leaks).
Any other converter replacement must be with a 'certified' or new original equipment (OE) or equivalent converter.
Aftermarket converters subject to the enforcement policy requirements cannot be used for replacement if:
(1) the existing converter is present and functioning properly; or
(2) the replacement is under recall or warranty; or
(3) the vehicle is returning from overseas use.
Here's the link to the actual document:
http://www.epa.gov/OMS/cert/factshts/catcvrts.pdf
Old Aug 19, 2006 | 08:53 PM
Jason@Performance
Performance Nissan
They are:
^^^^ +1
An example of something that happend to me with high flow cats on my Z...
High flow cat element blew out, got stuck in my NISMO Exhaust canister, basicly blocked off the complete flow of exhaust,
Replace Cats, Replace Exhaust - my expense... no warranty...
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Li1ag
Sep 28, 2015 02:07 PM
