350z shifting
Old Aug 28, 2006 | 01:52 PM
pool350z's Avatar
pool350z
Default 350z shifting
have any of u gone from 3rd gear to 5th gear accidently? like u guys wanted to go to 3rd but actually went to 5th? im havin a problem with that.
Old Aug 28, 2006 | 01:53 PM
BlackZero6's Avatar
BlackZero6
theres nothing wrong with that...you just wont accelerate for crap , but other than that no probs
Old Aug 28, 2006 | 01:58 PM
xNeo's Avatar
xNeo
I used to do that all the time in my old VW, I don't think it has anything to do with the Z's tranny...just something you need to get used to.
Old Aug 28, 2006 | 02:09 PM
Aeromike03's Avatar
Aeromike03
Unhappy
What about going from redline in 3rd back down into second because I missed 4th? It certainly didn't sound good, but the car still seems to be ok. Any ideas what I might have taken off the life of my tranny?
Old Aug 28, 2006 | 02:12 PM
Gryphin's Avatar
Gryphin
wow...
Old Aug 28, 2006 | 02:17 PM
Aeromike03's Avatar
Aeromike03
Unhappy
Yeah, I hadn't had the car that long, maybe 2 months at the time. I was doing a 1/4 mile run for probably the 5th time and was really getting after it. I threw her into 2nd by mistake. It felt and sounded to me like the clutch just slipped and never grabbed, but I don't know for sure. The clutch was only in about a second tops, as I put it in neutral as fast as I could. I was sick to my stomach for a week!
Old Aug 28, 2006 | 02:47 PM
highside107's Avatar
highside107
I did that before too, once. Car seems fine.
Old Aug 28, 2006 | 04:17 PM
LegionnaireZ's Avatar
LegionnaireZ
i don;t think slipping up once or twice is really going to hurt the car... but don't screw up too much... it might get costly...
but shifting from 3rd to 5th won't hurt your car... just as mentioned you won't accelerate much...
i even sometimes run 3rd to about 4K or 4.5K and shift to 5th... usually just around town or just getting on the freeway...
i use the lower gear to get going... then when i'm at the speed i need i shift into "overdrive" 6th... i've had the car a little over 1-1/2 years and no problems yet...
Old Aug 28, 2006 | 04:30 PM
GlassCurtain's Avatar
GlassCurtain
yeah it won't hurt your car. just when your shifting to third just make sure your not putting any directional pressure on it. when I first was learning stick my friend showed me that you have it in neutral and just push from the back of the shifter with a few fingers and it just pops in.
Old Aug 28, 2006 | 05:37 PM
Swiffer's Avatar
Swiffer
This is my first manual transmission car, and I've only missed a shift once. I found the gears quite easy to find when shifting. Not sure how this car compares to other in this aspect though.
Old Aug 28, 2006 | 08:06 PM
Zmazing03's Avatar
Zmazing03
I skip gears in this car when driving around town rather often. 3rd to 5th or 4th to 6th is very common. Won't do anything to the car.
Old Aug 28, 2006 | 11:49 PM
lilaznxboi08's Avatar
lilaznxboi08
happens all the time youll get usto it.
Old Aug 29, 2006 | 05:18 AM
Mathys's Avatar
Mathys
If it happens more often, missing 3rd when going up or missing 4th when going down, just put the gear in neutral and push it straight up or down. Can't miss it that way. Just takes some more time, so less effective when trying to get away
Old Aug 29, 2006 | 06:30 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
You need to relax on the stick, it should center to 3 so when you go from 2nd to 3rd, push it forward, let it center and push it forward again.
Chris
Old Aug 29, 2006 | 07:19 AM
Spideynw's Avatar
Spideynw
No.
Old Aug 29, 2006 | 09:29 AM
LegionnaireZ
Chris
exactly, the Z's shifter is quite stiff... it will always recenter itself when left in neutral... third and forth is just a matter of up or down then....
sounds like you're trying too hard... relax... lol
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
apex locator
Oct 6, 2015 05:58 PM
codek
Sep 28, 2015 03:03 AM
