About VDC
on
About VDC
I want to change my suspension and sway bar, but
when I surfed on another website, any vehicle with a VDC
cannot replace with another suspension. If I change my suspension,
does my VDC effect disappear?
Also, if there any suspensions that can be used for VDC vehicles?
Please reply ASAP
Please reply ASAP
on
Everyone changes their suspension. I have an 04.5 I have Greddy suspension and VDC and everything works fine. I also have new camber arms and toe bolts in the rear. Go for it youll be amazed at how different the car is after you drop the S**T out of it. Check out my past posts and look at the post of my car.
Hope that helps!
Hope that helps!
Administrator
Originally Posted by hndumafia
+1 fear not. your vdc will continue to work just fine.
Actually, the NISMO brochures for the LMGT4 wheels and the S-Tuned suspension both used to include a disclaimer that those products were not for use on a VDC equipped car. Nissan was covering their *** in case you had VDC issues.
Sure, everybody has replaced wheels and suspension and not had problems but technically, there is a remote chance than they COULD affect VDC. VDC is tied to the G-force sensor in the car, major changes in the ride and handling could theoretically change the way the G-force sensor behaves, in turn affecting VDC.
The bottom line is, don't worry about it.
HoneyBadgerRy
09-21-2015 03:25 PM
koolzero
11-20-2002 12:53 PM
