jwt pop charger rasp
Old Oct 27, 2006 | 08:03 PM
rory's Avatar
rory
Default jwt pop charger rasp
When I was leaving the driving range tonight. Wot on 1st, 2nd, 3rd gear to redline and I am getting raspy sound at high rpm. 2005 base with a jwt pop charger. It was warmed up. its a little cold, no rain. Has anyone had this problem? Its in the garage now, I looked at the intake and it’s all tightened down. Any ideas? Help me. I am looking for the OEM intake so I can test and see if it’s that or not. Ill post tomorrow.
Old Oct 27, 2006 | 08:14 PM
thirty5ounces's Avatar
thirty5ounces
you should hear a hissing noise, i wouldnt call it raspy, motor will sound a little beefer tho wot...i think you might be overreacting
Old Oct 27, 2006 | 08:26 PM
rory's Avatar
rory
no, its not that i have had jwt pop charger on for 10 months. it sounds the same but at WOT its sonds different NOW. same 1k-4k after 4k to redline its raspy. it sounds even louder at high rpm NOW. what do i do. its not the little hiss sound when you blip the gas. the filter is clean.
Old Oct 27, 2006 | 08:31 PM
jakedajewel's Avatar
jakedajewel
is the filter clean??
Old Oct 27, 2006 | 10:18 PM
zand02max's Avatar
zand02max
Uhm thats normal at WOT!
Old Oct 28, 2006 | 05:26 AM
rory's Avatar
rory
the filter is clean. no its not the same at wot. now it sounds different
Old Oct 29, 2006 | 12:55 AM
aren21's Avatar
aren21
check to see if you have any leaks, something might have gotten loose. Its not supposed to rasp near redline, it just screams!!!
Old Oct 29, 2006 | 03:33 AM
thirty5ounces
yea i agree but, i would think he would have put it on correctly, i would go back and double check everything tho, maybe you have a defeccted filter?
Old Oct 29, 2006 | 05:02 AM
Combat350z's Avatar
Combat350z
Dude your Z's gonna blow. Thats all there is to it she going to explode.
Sorry to be the bearer of bad news
Old Oct 29, 2006 | 07:43 AM
ZlleH's Avatar
ZlleH
Usually rasp is attributed to exhaust. Your exhaust will always be a little different in the cold weather.
Old Oct 29, 2006 | 09:11 AM
Swiffer's Avatar
Swiffer
^1. The intake should not induce rasp, it is usually caused by the exhaust.
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
_bit
Oct 2, 2015 07:49 AM
