Gas gauge inaccuracy
Old Sep 21, 2007 | 01:15 AM
  #81
Z_Driver's Avatar
Z_Driver
Master
Originally Posted by JAB_06-350Z
So far the gas gauge seems to be very accurate on my '06. Hope it stays that way.
My 04.5 meters perfectly too. Low light comes on at about 3 gallons left. Maybe I have a factory freak. Perfect to me. I fill up at all different types of stations with no premature shut off issues.
Old Sep 21, 2007 | 01:17 AM
  #82
Z_Driver's Avatar
Z_Driver
Master
Originally Posted by Jes-Z
I think I'm going to try that. Truthfully. Once I see the lines I get a little worried. But I know that I have plenty of gas to go. I think I've maxxed out @ 270 miles on a tank. I've only ever pumped a max of 15-16 gallons.
??? The best mileage is 18mpg. WTF? Time for a tune up? Or, do you do a lot of in town driving?
Old Sep 21, 2007 | 01:21 AM
  #83
Z_Driver's Avatar
Z_Driver
Master
Originally Posted by bailey bill
Except for newer cars with digital fuel gauge systems (like the Z), all cars are like that.
Conventional auto fuel gauges are NOT linear.
bill
Yeah, that how I saw it too. The older cars I have are more inacurrate. The one on my Z seems to be really accurate.
Old Sep 21, 2007 | 03:42 AM
  #84
Swiffer's Avatar
Swiffer
Mine always has about 3 gallons left once it reaches 'E'.
Old Sep 27, 2007 | 07:29 PM
  #85
EvanV's Avatar
EvanV
Well it seems my gas guage is working... I only drove 350 miles, but my car just died on me in the middle of a busy intersection (almost died when I was in the middle of the intersection).. Luckily I had enough power to get to the side of the lane and put on my hazards.. Filled up with 5 litres from a gas station down the street and got home to fill up the rest.. filled it with 70.1 Litres (so around 75 total), but the tank should be 80 litres... Never ran out of gas before in my life.. hope I didn't mess up anything on the car.. anyone know what could be damaged (fuel pump?).. I tried to start it after it died on me about three or four times in a few minutes but no luck. When I put gas in, I turned key to ON position for a few seconds.. back off.. and back on again.. then off.. then fired it up. sputtered at first just under 1k RPM, then shot up to 3000 and down to 900...
Old Sep 29, 2007 | 07:34 AM
  #86
RX350Z's Avatar
RX350Z
dealing w. this issue too, dealer is replacing fuel sensor array.
Old Sep 29, 2007 | 07:51 AM
  #87
07_350Z's Avatar
07_350Z
i havent experienced this yet. my gauge seems pretty accurate so far. i filled up at halfway under the 3/4 full mark and it took 6 gallons. i know the 300zx has a similar problem. even when the light comes on the car still has 5 gallons left. the capacity for that car is 18.7 gallons but ive never put more than 13 in.
Old Dec 12, 2007 | 03:32 PM
  #88
AreBe's Avatar
AreBe
When I fill my car, it shows right at the full mark - not past the mark. You can notice needle movement after about 10 miles so the tank must not register full. Last week, I filled the car and the put 425 miles on it with the mileage computer showing 25.8 MPG. The needle was just below the empty mark, the yellow light had been on for the last 50 miles and the DTE was flashing - - -. I filled up with 16.3 gallons, so my math shows slightly over 26 MPG, and I should have been able to go about another 96 miles.
I sniveled about this a few times when I had the car in for service and they don't think it's a big deal. They even filled my tank once (at today's prices, a nice gesture) to "prove" that the thing shows full. They only proved that they don't get it. So other than it being a minor irritation, s'ok.
The Z is: 2007 Grand Touring coupe, San Marion blue, 6 speed, NISMO Catback exhaust.
Old Jan 23, 2008 | 07:55 PM
  #89
03aeroZ's Avatar
03aeroZ
did that fix it....if so, how much was it? i have a couple small things to fix, figured while it is in, might as well fix that too, it drives me insane!
Old Feb 4, 2008 | 04:15 PM
  #90
Beka Z's Avatar
Beka Z
This issue really just kicked in on my 2003 today. Filled up last night, drove 24 miles and now it won't come off half a tank! ARRRGH!
Old Feb 4, 2008 | 10:08 PM
  #91
wazhucks's Avatar
wazhucks
i once had this problem. my gas gauge or line was near the E before i parked it. After a couple of hours i start it up again and the line was past the E. It was the strangest thing i seen my Z do. I thought maybe i had a gas leak or osmething but after turning the car off and back on again it went back to where it should be.
Old Feb 6, 2008 | 04:06 AM
  #92
03aeroZ's Avatar
03aeroZ
so has anyone been able to get it fixed and covered under warrenty?
Old Feb 6, 2008 | 04:37 AM
  #93
2007 Z's Avatar
2007 Z
The guage in my 07' appears to work exactly like it should. When I get to "----" and fill it up I can put in about 17.5-18 gallons. That is ideal since it's not good to run your tank completely empty. Plus I've read that if the tank gets almost empty then the fuel pump is no longer submerged in gas and therefore gets hotter and could potentially burn out.
I have only had the pump shut off a few times before the tank was actually full. I just pulled the pump out and put it back in and restarted pumping then the tank continued filling to full. It's like air got trapped and cut off the fuel flow into the tank or something. But removing and re-inserting the pump seemed to fix the issue.
Some of you sound like you have legitimate problems that the dealer should investigate.
Old Feb 6, 2008 | 06:35 AM
  #94
cspinner's Avatar
cspinner
I had the same problem in my Audi TT. I had to take an alcohol swab to the sensor contacts of my fuel senders and everything worked after that.
Old Feb 6, 2008 | 07:18 AM
  #95
SRTtoZ's Avatar
SRTtoZ
Wow I just started having a similiar problem...
When I was on Empty last night with the gas light I went to fill up, I only filled up to 14.5 gallons and thats with me Rounding off to the nearest Dollar so It wanted to stop earlier.
If I have a 20 gallon tank, how could it fill up at under 15 gallons! So I guess I have about 4-5 gallons left?
Old Feb 6, 2008 | 07:19 AM
  #96
Donsred350Z's Avatar
Donsred350Z
I agree my 05 350Z rarely register a full tank until I go over a bump or something. Sometimes it does but thats true with my 2001 Infiniti also to be fair most of the time it does show full without the added trip over the rail road track that the Z needs.
Old Feb 15, 2008 | 05:54 PM
  #97
03aeroZ's Avatar
03aeroZ
ok...again, has anyone found out if this is covered under warranty to fix? also, is everyone having the same problem and if they are, how much is it if you have to pay for it. mine is driving me nuts.....drove 25miles and dropped 1/4 of a tank! but when all is said and done, i end up w/ 22mpg at each fill up.
Old Feb 16, 2008 | 09:44 AM
  #98
silverbullet_Z's Avatar
silverbullet_Z
when i fill up my 03 the gauge only reads that i'm at half a tank....
Old Feb 19, 2008 | 06:13 PM
  #99
03aeroZ's Avatar
03aeroZ
ok, i just found out, if it is the fuel sending unit sensor, which it usually is apparently, it is $300-350 (parts and labor). just fyi
Old Sep 15, 2008 | 07:32 PM
  #100
BlackSpec02's Avatar
BlackSpec02
Anyone try any fuel system cleaners for this? My buddy who used to be a tech at the benz dealership said that sometimes he would see this happen to cars because the sensor in the tank would get gummed up.
