downside of ZZZZZZ
Just a guess...
Your engine still powers the power steering and alternator through the belts. At a higher speed, meaning not stopped: You car want's to keep
the engine at an RPM the can sustain normal operation of the other
components. Kinda like if you turn your steering wheel while sitting still...
The RPM spikes as the power steering sensor can tell a need for more
pressure so the engine revs up to turn the power steering pully more.
Uhmmm
Originally Posted by Master Shake
OK, here's one I never understood -- and this applies to multiple brands, not just the Z.
When you are at an RPM speed higher than idle and you put your car in neutral, why is the RPM slightly higher than when the car is in neutral, but at 0 speed?
For example, driving at 40 MPH and put the car in neutral. My RPM is around 1K all the way until my speed is at 0 (or actually less than 5 MPH). At that point, the RPM returns to around 800.
Since modern cars no longer have a cooling fan driven by the motor, why does this happen?
Originally Posted by bboypuertoroc
Don't whine about it... you got a ****ing sports car. What the hell you expect, the mileage of a Prius?
I get ~240 out of my Evo, but I don't whine like a crybaby about it... it's to be expected.
Try this - shift at 2000 rpm, drive 5mph below the speed limit and... might as well sell your car and get a honda civic instead!
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
350zQ45a
Oct 13, 2005 08:44 PM
sharingan625
May 24, 2005 02:52 PM
