Just hit 60,000 tonight. Recap of problems to date
Old Jul 27, 2007 | 04:50 PM
  #61
SSZVirginia's Avatar
SSZVirginia
Originally Posted by iceagetlc
Thought I'd share the list of problems I've had had with my 03 up to now.
- Replaced transmission at 45,000. Grind into third
- Rear axle click at 20,000
- Window motor needed reset at 42,000 _ NEVER DONE
- Window grease on occasion. Seems to be random
- Only changed tires once. Rears at 51,000 and fronts at 58,000. TIRES LAST 20k
- Interior pieces such as radio controls and turn signal/wiper stems started to fade and discolor at around 55,000 CD PLAYER INOPERATIVE AT 40k
- Only changed clutch once, was done with transmission at 39,000 but didn't even need it then. HAD DONE AT 45k
-Oil changed every 3,000 or less with no signs of loss.
-Gas gauge is totally inaccurate, I've never put more than $50 in even when it's flashing "---" at me on the dte. MINE WORKS
- Hatch hinges fail under cold temperatures - DITTO
- Electric gas door has lost it's oomph to open at about 55,000. I now have to get a fingernail under it to open it. ABOUT THE SAME
- A/C is starting lose it's cool at about 55,000 ABOUT THE SAME
Other than that, it's running pretty damn strong, and is ready to go F/I.
THANKS FOR THE WRITE-UP. THE CAR STILL FEELS STRONG BUT NOT WITH THE AC ON....
Old Jul 27, 2007 | 04:51 PM
  #62
ScoobyDoobyDude's Avatar
ScoobyDoobyDude
I am amazed that you all have had so many transmisison problems. I drive my 2003 touring Z hard on occasion but I don't power-shift, I always rev-match when I downshift, and I have never taken it on a track. The car has a little over 21,000 miles on it now [I got it in February on a lease trade-in]. Is it likely that I will experience the same problems? I'd expect that kind of performance from a Ford, but not from a $30,000+ Japanese vehicle!
Old Aug 1, 2007 | 08:39 PM
  #63
ceevee's Avatar
ceevee
Very common with my list. Not funny though.
Old Aug 1, 2007 | 11:43 PM
  #64
iceagetlc's Avatar
iceagetlc
Originally Posted by Eliane
51k with the rear tires seems like a phenomenon to me. How did you do this?
Highway miles, no drifting, burnouts, etc...
Old Aug 2, 2007 | 09:00 AM
  #65
Alex3000GT's Avatar
Alex3000GT
Holy expensive! $$$ Why was the entire transmission replaced as opposed to rebuild/new synchros? Is there something I don't know?
Old Aug 2, 2007 | 09:52 AM
  #66
iceagetlc's Avatar
iceagetlc
Holy free is more like it. Waranteed.
Old Aug 2, 2007 | 01:18 PM
  #67
WangZ808's Avatar
WangZ808
lol...my cup holder is starting to act up at 50k. oh yeah, the stuff that holds your windsheild in place, it has started to crack and looks like shi*t...that and the window motors suck.. i love my Z!! no other complaints
Old Aug 3, 2007 | 08:25 AM
  #68
iknowitsfast's Avatar
iknowitsfast
Im totally ignorant of this, but what type of warranty does the 03 Z have on the transmission? im at 55,000 miles now, is it still under warranty?
Old Aug 3, 2007 | 01:03 PM
  #69
Spike100's Avatar
Spike100
Yes... but only for drivetrain warranty (5 yrs/60K miles). You are still under warranty for your transmission. If you are having any issues, get the car to a dealer now.
--Spike
Old Aug 3, 2007 | 08:08 PM
  #70
Beaker02's Avatar
Beaker02
My 03 is at 71K. Lets check your list and see how I compare.
- Replaced transmission at 39,000. Grind into third
< Replaced mine around 50K. 5th gear grind on downshift
- Rear axle click at 45,000
< No problem.
< Reset or replaced both sides 3 times.
< Agreed
< Wow! On my 3rd set.
< No problem
< No problem
< Same
< I find mine to be as acurate as any car i've owned.
< Yep. Creek & moan. Springs work just fine after replacing srings and adding pennies.
< Mine has had that problem sence day one. Going to try the WD40 thing.
< No problem.
Old Nov 12, 2007 | 06:16 PM
  #71
deezz's Avatar
deezz
I just hit 60,050 miles and my gas guage does not work at all. I have an 04.5 Z. Was this something that was covered up to 60,000miles?
Old Nov 13, 2007 | 03:36 AM
  #72
bjr's Avatar
bjr
Originally Posted by stalarman@yahoo
wait! question, so when youre nearing say, 14 miles till empty (dte) and the flat line shows.. you still have 3 GALLONS left? are you sure about this? i always get paranoid and drift neutral down the hill... are you positive?
If mine goes below about 45 miles to empty the --- always comes on at this time. And you have about 3 gallons left I'd say also. Fill up takes a little over 17 gallons - and we have a 20 gallon tank.
If people arent' paying attention do you really think that the car would wait and warn you that you are just about to run out of gas? What if you were on the highway and the next exit was 10 miles away?! You get plenty of warning if you did not plan ahead. I can have the gas light and "---" come on leaving work and drive 30 miles to home and buy gas where it is much cheaper and the actual needle on the E to F gauge just moves about the width of the needle. Usually the DTE display automatically switches over and reads around 43 or 45 miles to empty and within a minute or so goes to "---". This is normal and would bet it is this way in almost any car. How long have you been driving anyway?
Old Nov 13, 2007 | 09:25 AM
  #73
jcrocka288's Avatar
jcrocka288
what is the rear axle click from..i have just recently started to hear that right as i go start to out of 1st gear?? sounds like what you call the rear axle click might be exactly what im hearing ...and if so how do u fix it or is it serious ? (2004 z)
Old Nov 13, 2007 | 09:50 AM
  #74
reis's Avatar
reis
I bought mine used in back in September with ~61200 Miles on it. Currently at 64500. Almost all highway miles.
I have two potential issues with the Z at this point:
1) At exactly 79 MPH, continuing on until the mid 80's, there is a steady whine that goes away at 86 & above. Usually it stops once I'm past 82. Sound seems like it's coming from behind the dash, in the middle of the car.
2) If I am accelerating somewhat hard in 1-3 gears, there is a whine/screech that sounds remarkably like dragging across metal. This I can also reproduce this sound at a stand still in neutral with a quick rev of the engine (blip from idle to 2k).
Is my tranners screwed? I have a pretty good warranty I bought with the car used, so I might be able to get it replaced still.
Makes me sad that the other day I found the original owner had 75k mi warranty, but that wasn't transfered to the dealership that the guy traded the car into. Coulda had that sucker....
Uriyo_
Sep 8, 2021 08:46 AM
