Stealership wasted my time
Originally Posted by jtabraham
I find that speaking with the owner of a dealership is far more effective when you find yourself getting the run-around from techs or managers. An owner will always see an unsatisfied customer as many potential lost sales and are more likely going to listen to your concerns.
Please use a different dealership. No reason to keep hounding one that does not care to fix it. Do you think they would do a quality job if it was forced to work on your car?
Take it to another dealership that actually cares about customers and Zs!
I just called Stateline Nissan about my 03 tranny that started grinding in 3rd this week (ugh). So far, (knock on wood) they have been a pleasure to work with and seem willing to fix the problem under the powertrain warranty. I might look into axle clicking if the warranty is really up next month or so.
[QUOTE=HitLines]Please use a different dealership. No reason to keep hounding one that does not care to fix it. Do you think they would do a quality job if it was forced to work on your car?
I did bring it to two others. They said the same crap. Im going to fix this myself.
Originally Posted by Tim@Performance
Drive shafts are covered under powertrain. The axle is part of the drive shaft. Covered...should be no questions asked.
I really doubt that. Just lazy / unknowing manager.
If this is truely the axle clicking or bearing issue which we all expect it is... Should be a non-issue.
Originally Posted by Mr_Kebo
Yes all 350z came with the 5yr/60k powertrain warranty. Yours is an 03 also like mine and my powertrain warranty will be up in october they said.
