can i be denied warantee? broken axels!!!!!
Old Jan 3, 2008 | 02:40 PM
duckypower's Avatar
duckypower
Default can i be denied warantee? broken axels!!!!!
i broke them once on fontana speed way. they replaced with out arguing
2 months later i broke trying to do a burnout!!!!!
Old Jan 3, 2008 | 02:43 PM
JasonZ-YA's Avatar
JasonZ-YA
geeeessss....
Old Jan 3, 2008 | 02:44 PM
iStan's Avatar
iStan
ZR
nm
Old Jan 3, 2008 | 02:46 PM
duckypower's Avatar
duckypower
the thing is I have done burnout many times with no problem, but this was the first time i have done one since they replaced my axel.......
Old Jan 3, 2008 | 03:17 PM
DavesZ#3's Avatar
DavesZ#3
I'd say your chances are slim to none. Axle failure could easily be possible - once. Twice - they're going to suspect and claim abuse. I would at least expect an argument from the dealer/Nissan.
Old Jan 3, 2008 | 03:19 PM
duckypower's Avatar
duckypower
what should i say? i really dont have anything that adds major hp that would break my axels that easly
Old Jan 3, 2008 | 03:20 PM
SuperBlack350z's Avatar
SuperBlack350z
you don't need extra hp to break axles, like you said, you were doing a burn out. That's abuse to the car.
Old Jan 3, 2008 | 03:25 PM
350ZTheStandard's Avatar
350ZTheStandard
NO... I believe the NiSSAn stealership will love you enuFF to replace as many sets of axels you can damage
Old Jan 3, 2008 | 03:52 PM
DavesZ#3's Avatar
DavesZ#3
Like I said, the first time you can tell them just about anything. The second time a lot harder. I'm not sure what kind of "normal" use your could claim that would have caused them to break.
Old Jan 3, 2008 | 03:57 PM
HDPDZO6's Avatar
HDPDZO6
Anyone who doesn't know what they are doing can break a stock axle...
Old Jan 3, 2008 | 04:00 PM
JonsilvZ's Avatar
JonsilvZ
Never heard of breaking axles just from burnouts but from 6k rpm clutch drops thats possible.
Old Jan 3, 2008 | 04:23 PM
CaliTouring's Avatar
CaliTouring
you wont get a new axle because they dont have anymore. ive broken all of them!
Old Jan 3, 2008 | 04:26 PM
Russ@Z1's Avatar
Russ@Z1
OP - The answer is yes, you CAN be denied warranty if the dealer deems fit. From your explanation, I'd escort you to the sales department of another dealership.
Old Jan 3, 2008 | 05:52 PM
JETPILOT's Avatar
JETPILOT
Were you on slicks or drag radials?
JET
Old Jan 3, 2008 | 06:00 PM
blktrack350's Avatar
blktrack350
They would have to show proof that it was abuse that caused it to happen, if you havent told them what really happened
Old Jan 3, 2008 | 06:04 PM
Al_s14's Avatar
Al_s14
this is such an inexpensive claim that they will not likely bother. but if they do not much can be done...suspecting abuse wont do jack and unless they can prove it with evidence you got nothing to worry about.
Old Jan 3, 2008 | 06:05 PM
Bary626's Avatar
Bary626
2 months is proof enough!
Old Jan 3, 2008 | 06:11 PM
DavesZ#3's Avatar
DavesZ#3
You're confusing this with aftermarket warranty claims. The dealer/Nissan has to prove that an aftermarket part caused a problem to deny you warranty coverage for that problem.
In this case, by virtue of the rapid failure of a part that under normal wear and tear should never fail, they will assert that it had to be abuse that caused the failure. His only hope is to claim and prove that the previous axels were defective, installed improperly or there is some other fundamental problem with his car that is causing them to fail prematurely.
Old Jan 3, 2008 | 06:23 PM
350 Rookie's Avatar
350 Rookie
make sure you tires arent bald or they'll reject automatically.
Old Jan 3, 2008 | 07:34 PM
Agree. As a service manager I would tell you no. Twice in two months is not a material deficiency, its abuse. Sorry.
EDIT: Besides I don't think you want OEM rear axles anyway.
