---Winter storage Z---
Old Oct 16, 2009 | 06:23 PM
  #41
2005newb's Avatar
2005newb
another good thing to do when storing a vehicle for a long period of time is to put a plastic sheet under the whole car. it helps stop moisture from getting to the car from the ground. a lot a classic car owners due this while storing there cherished rides.
Old Oct 18, 2009 | 06:57 PM
  #42
Izzysparks3's Avatar
Izzysparks3
https://my350z.com/forum/maintenance...he-winter.html
  #43
Izzysparks3
This should cover anything you missed.
Old Oct 19, 2009 | 07:36 PM
  #44
pfft's Avatar
pfft
Originally Posted by Fire_4_Effect
battery charger? just disconnect the negative and you are done. don't invest any more than you have to, especially in this recession
Is it good enough to just disconnect the negative and leave the battery in the car or should you remove the battery and store inside? Forgive my ignorance.
Old Oct 20, 2009 | 06:13 AM
  #45
Fire_4_Effect's Avatar
Fire_4_Effect
i just disconnect the negative and leave the battery as-is; i usually store my rides in a storage unit and never had any issue with this. i guess you can also remove the battery if you'd like, either way, your question was a good one!
SpartanZ32
Oct 22, 2015 09:36 AM
aestus
350Z Roadster
29
Apr 18, 2003 05:46 AM
ZISBAK
Apr 6, 2003 05:00 AM
c350z
Aug 14, 2002 09:48 AM
zmain
Jun 17, 2002 03:27 AM
