Buying a 2003, tranny concerns.
Old Mar 25, 2009 | 07:22 PM
neox's Avatar
neox
Default Buying a 2003, tranny concerns.
Total'd my 2004, going to buy an identical 2003 with 50k miles for $12,000 tomorrow. Clean carfax, only necessary service work was a window motor replacement. (common problem in the 2003s) My concern is that the 2003s are also known for having a syncro go out in the transmission. (right?) If one was going to go bad, wouldn't it have done it already by 50,000 miles?
How should I look for signs of a bad tranny when I go on my test drive? Obviously grinding gears would be a good indication, but should I run it hard and shift at redline a few times to make a syncronizer act up?
The car was manufactured in March 2003 if that matters. Any help/guidance would be appreciated.
Old Mar 25, 2009 | 07:51 PM
BallZdeepNYC's Avatar
BallZdeepNYC
make sure fifth gear doesnt grind above 4500 rpms keep the rpms at 5k or more and shift hard under load
Old Mar 26, 2009 | 07:21 AM
MRfire's Avatar
MRfire
My 03 has 48k on it and I only get an occasional grind in 3rd when it's cold. I would try to run it through the gears before the temp gets up to normal.
Old Mar 26, 2009 | 08:40 AM
silverbullet_Z's Avatar
silverbullet_Z
Dont know if you've read it or not but this will also give you an idea https://my350z.com/forum/engine-and-...nsmission.html i have an 03 with 42k on it so far so good (knocks on wood)
Old Mar 26, 2009 | 01:14 PM
3-fifty-WeEe's Avatar
3-fifty-WeEe
ive got an 03 with 150 on it man, it pulls smooth and hard, shifts like a dream i dunno what all this fuss is about
Old Mar 26, 2009 | 01:42 PM
m3a5g0's Avatar
m3a5g0
hey man...I just bought an 03 about a month ago with 54k. I had no idea that 03's had a common 3rd gear sync going bad untill....it happened to me. It doesnt matter what temp it is outside, it grinds when I try to shift any faster than grandma. I havent noticed any other grinds except shifting in and out of third. I've pounded all other gears just to make sure and they're perfect. If you buy one...get some kinda warranty...i've done some research and many people have had nissan replace it....it also gives u an excuse to drop a new clutch and flywheel while your at it ! Currently i'm still waiting to get my warranty transferred so i can get this tranny dropped and gone! hope this helps
Old Mar 26, 2009 | 08:12 PM
If you are concerned then maybe skip the 2003.
Old Mar 27, 2009 | 02:44 AM
SSZVirginia's Avatar
SSZVirginia
Check with Nissan to see if the trans has been replaced. I would also offer $1K less than $12.
Old Mar 27, 2009 | 03:46 AM
TSF09ZR's Avatar
TSF09ZR
If you really want that Z, I would find out how much it is to replace the trans then reduce your offer by half that amount. Your exposure is cut by 1/2 if you should lose the trans down the road.
Old Jul 2, 2009 | 08:29 PM
2005 Nissan 350Z Enthusiast
Congratulations.
Old Jul 2, 2009 | 10:14 PM
Ix350xI's Avatar
Ix350xI
in my 03 my 3rd gear sync does whine but how bad is that really? will it affect my trans and if so how much would it to be replace it or fix the 3rd gear sync? thanks guys
Old Jul 3, 2009 | 04:51 AM
sleeperbold's Avatar
sleeperbold
A bad tranny? LOL idk, look for razor burn, five o'clock shadow... ;-)
Old Jul 3, 2009 | 05:34 PM
ZeroFear's Avatar
ZeroFear
I have an 03 with 14K miles. 2nd gear makes a VERY nasty sound going from 1 - 2 over 5500RPM under load. Sounds like the world is ending. All other gears are fine.
Old Jul 4, 2009 | 01:23 PM
Resmarted's Avatar
Resmarted
I think if you row through the gears, and they don't grind (try once low speed and once 1-3 under good load 5.5krpm) you should be ok. Could just go with a newer Z to be safe.
The gearboxes are pretty stout, Sound Performance has a 1200whpish Z running a stock gearbox(+clutch and others obviously). And it held up pretty well.
There are some gearboxes out there that just tend to have crappy 3rds and 2nds.
apex locator
Jul 23, 2021 02:27 AM
Mattg350z
Oct 2, 2015 06:51 AM
