Looking Into a 2003 350z
Old Jul 29, 2009 | 10:53 PM
rcarr88's Avatar
rcarr88
Default Looking Into a 2003 350z
Hey guys, I'm not quite a Z owner yet but will be soon. I was wondering if there are any issues that I need to be careful about since I am buying an 03. Especially with it being the first year the car came out. I have heard about the tire feathering, but was wondering if there are any other issues I should be worried about. The one I am looking into is a touring package with 44000 miles on it.
Old Jul 29, 2009 | 11:14 PM
ITOzann's Avatar
ITOzann
google...
Old Jul 29, 2009 | 11:24 PM
Gibbs's Avatar
Gibbs
Know it all
Do a quick search on this site to find the main things you need to look out for. Check the carfax info. And when buying a used car it is always a good idea to get it inspected by a mechanic that isn't associated with the dealer, that way you have the highest chance of getting an unbiased opinion. Also take it for a test drive and just use good common sense.
Old Jul 30, 2009 | 06:29 AM
Check the windows. If the go up and down you are good to go.
Old Jul 30, 2009 | 07:23 AM
VO...'s Avatar
VO...
Administrator
Read:
https://my350z.com/forum/2003-2008-n...questions.html
Old Jul 30, 2009 | 06:16 PM
Swisherlord's Avatar
Swisherlord
brakes, brakes, brakes. Also, sometimes the exhaust pipes stick out one further than the other. Mine does that and i've seen many 03's have the same problem......but nothing a few hundred bucks can't fix with aftemarket parts
Old Jul 30, 2009 | 06:17 PM
Swisherlord
Also, sometimes shifting makes clunking noises. it's normal. Just something to get used to. Some do it and some don't.
Old Jul 30, 2009 | 06:22 PM
Globalscan's Avatar
Globalscan
I had a 03, loved it. The only problem was front end alignment issues eating tires. Nissan replaced with 2 new Bridgestones.
Old Jul 30, 2009 | 09:10 PM
dynamic21's Avatar
dynamic21
lol tire feathering and window motor's are actually the easier problems to take care of... 6Spd Transmissions are arguably the biggest problems you can run into with the 2003's. The synchro in 3rd going out is the most common I believe. Test drive it, make sure that transmission shifts into each gear without any grinding or the need for excessive force to get it into gear.
Other than that, the engine is amazing, the car is sexy, and the other problems aren't too bad. Transmission transmission transmission!!
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
foxsmp26
Sep 25, 2015 09:48 AM
RWDBajan
Sep 8, 2015 06:25 AM
