FX45 Engine in 350Z?
Old Oct 21, 2003 | 06:22 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Default FX45 Engine in 350Z?
Can this be done? If so how expensive and how much potential does that engine have?
Old Oct 21, 2003 | 06:29 PM
ares's Avatar
ares
Veteran
well youd have to go all custom at that point, cause its not likely thered be much room left for anything not that there are many performance parts made for the SUV anyway.
your weight balance would be all off, so handling would suffer.
if you had TONS of cash, it might be worthwhile, but probably not.
Old Oct 21, 2003 | 06:33 PM
EnthuZiast's Avatar
EnthuZiast
Guess your right....part of me just wonders what a V8 would do in this very capable Z.
Old Oct 21, 2003 | 06:38 PM
rouxeny's Avatar
rouxeny
I think it would make it go very fast.
That's just my opinion.
Interesting idea, but probably technically difficult if not impossible.
Old Oct 21, 2003 | 06:40 PM
EnthuZiast's Avatar
EnthuZiast
Someone here can figure it out....just not me.
Old Oct 21, 2003 | 07:42 PM
FLY BY Z's Avatar
FLY BY Z
You'd also need a new ECU entirely. Not the one in the Z or the one in the FX. A hybrid computer. Too much trouble when there is a FI kit waiting for much less moolah. I have dreamed of this too.
Old Oct 21, 2003 | 07:46 PM
KONVERTER's Avatar
KONVERTER
just bore out the 3.5L engine and make it a 4.0...
much lighter... better off that way
Old Oct 21, 2003 | 09:28 PM
MY350Z.COM's Avatar
i don't think the suspension would fit.
engine will fit for sure since it utilizes the same chassis as the z.
Old Oct 21, 2003 | 10:31 PM
EnthuZiast's Avatar
EnthuZiast
Looks like my dream will stay a dream
Old Oct 21, 2003 | 10:46 PM
Dissident's Avatar
Dissident
I bet it'd be easier int he G35, which I think has the same wheelbase...
Old Oct 22, 2003 | 06:07 AM
toykilla's Avatar
toykilla
wow back to what i was saying months ago
Old Oct 22, 2003 | 07:20 AM
Dissolved's Avatar
Dissolved
sorry, but WTF would you want a v8 in a z for? Zs have always had 6cyl's and it should stay that way. I can understand doing an RB26DETT swap but not V8. That's just retarded. May as well put an LS1 in there if you're going to do that
Old Oct 22, 2003 | 07:48 AM
350zSpeedRacer's Avatar
350zSpeedRacer
I actually know of someone who's putting an LS1 in a G35C. Can't say who, though, I was sworn to secrecy.
It's not a bad idea, motor swaps are very effective when done right. Hell, I've done one myself. I just have a feeling that the 4.5 L V8 that's in the Infiniti would take a TON of work to get running right. It'd be a great project, but not something you could do with a daily driver.
Old Oct 22, 2003 | 07:55 AM
wildone_106's Avatar
wildone_106
Cool
I never really understood motor swaps.
Is'nt it true at this point if you tear out a cars engine, its no longer the same car anymore I mean..take out the Z's engine and put in a honda's (Say) it'd be a honda with a Z body shell?!
At what point does the car cease to become the same vehicle, when you mod/change it all to hell so much its not correct to call it by the same name anymore! I think the only purpose is to *Fool* some shmuck in a road race into thinking he got beat by a stock car when in fact its a frankenstein machine?!
Old Oct 22, 2003 | 09:21 AM
Dissolved's Avatar
Dissolved
lmao what's wrong with some people? Does this guy in the G35 think we're going to bow down to him when he's done or something? I could put an LS1 in my lawnmower. He will be laughed at and just proved to the world he doesnt have enough brains to make the 3.5l run.
Wildone hit the nail on the head. Glad I'm not the only sane one here
Old Oct 22, 2003 | 09:24 AM
Mikestro's Avatar
Mikestro
you can't bore out our VQ35 engines, from what I understand they are aluminum block with steel sleeves. If you tried to bore, you would thin the sleeve. If you really wanted to do it, prolly have to bore the sleeve completely out and have a new sleeve designed.
Old Oct 22, 2003 | 09:39 AM
ares's Avatar
ares
Veteran
I beleive the engine is already bored out from the 3liter version... not sure if that was ever proven or not. but if it was true, not likely that it can be done a whole lot more...
Ill stick to a turbo, Im fairly certain the Z engine with that kind of money in it would put out plenty of horsepower to be considered death on wheels.
Old Oct 22, 2003 | 10:07 AM
jedoublery's Avatar
jedoublery
Some people (only some) swap engines because they blew their old ones. Might as well experiment with a more powerful one.
As far as putting a V8 in a Z.....why? There are tons other more reliable and cheaper way to acheive the same level of performace without suffering handling.
Old Oct 22, 2003 | 10:23 AM
350zSpeedRacer
Dude, no need to be rude about it. Some people just want to try something different. If I remember correctly, isn't putting a Chevy small block a VERY popular thing to do with some of the old 240 and 260Zs?
Just because it's not what you would do doesn't make it stupid.
Old Oct 22, 2003 | 10:28 AM
slaponte's Avatar
slaponte
There are some good valid resons for some swaps. A small block V8 on an RX7 became a common swap to the point there was a comercial kit available. Why? Rebuilding the RX engine was too expensive, while small block Chevys are dime a dozen and parts are cheap.
But I think most swap start with a "what if". It is a technical challenge, for those who like to solve problems. And you do end up with a "unique" (most of the time), could be a "Frankenstein", but yours might be the only one!
Underpowered cars : A lot of 4 and 6 Mavericks used to get 302 V8s on them. They fit, and you get better power for an underpowered car. Many 4 and V6 Mustangs get 302s in them as well.
I saw pictures of a V8 on a Bettle.
About dificulties : If you get the ECU and wiring with the donor V8 engine, I don't see why it would be so hard. Next you have to figure weight and suspension issues, which is a common issue to ANY engine swap.
And I HAVE heard of Zs (old ones) with V8s (Chevy) on them...
This is more likely to come about when some FX45s die on accidents (roll overs, etc) and some used engines/tran/ECU donor cars become available. Add that to a dead engine Z (maybe blown dead by a supercharger?), and you might have the birth of the FX-350Z
