pretty bad start to my weekend.
Its like 80 degrees today, so i decided ill drive my car to work today. Usually i just cruise around in it on nights and weekends. So im driving to work and im like about 5miles away from my job when all of a sudden i lose pressure in my clutch peddle. Immediately, i think to myself "ahhh ****, not again. Not now!!"
So i pull over to the side and park up. I already know what's wrong, my slave cylinder has failed for the 2nd time.
I ordered a spec super twin about a month ago and installed it, however i didnt change my slave cylinder since i figured it'd still be good because i only have 19k on the car. So 2 weeks after installation im driving and my clutch peddle loses pressure and all my brakes fluid leaks out. So i open up the transmission and saw that the slave cylinder popped. I call up spec and explain to them, they're shitty tech rep told me i shouldve bought a new slave cylinder during installation and put it in. So im like ok, maybe thats the problem.
I installed the new slave and here i am now. In the same exact situation, except today im missing a day of work and i have to dish out money for a tow truck. Im convinced now that the stock slave is incapable of handling the pressure from Spec's SuperTwin. Im going to call up Spec later and explain to them. I dont want their clutch system anymore, hopefully i can return it or something. This just sucks ***.
A twin disc requires less pressure from the hydraulic clutch system than a high load single disc would. It sounds like you may be getting too much travel on the slave cylinder. Did you install a clutch pedal stop when installing the clutch? On our twin disc clutches this is required to prevent over-travel of the system (which would blow out the slave cylinder).
If you do not have a pedal stop installed I would ask SPEC if they require one for their twin plate assemblies. We include a stop with all of our twin disc assemblies and will not warranty them if the stop is not installed.
I suspect that this may be causing your problems.
Interesting, ive never heard about that. Ill do more research on it to get a better idea. Im going to call up Spec and ask them to see what the deal is. Thanks for that very useful information.
lol.....what? I have never heard about a "travel" issue. You can always adjust the travel from the pedal itself regardless. Are you properly bleeding the system and double checking nothing is leaking from lines? I am surprised no one ever suspect that the parts are defective. That may be the issue.
A similar issue i had once with a G was the inner pin that pushes the fork had broken on the guy from god knows what. Caused the same issue after testing every other part. That was his problem.
Meh, might as well.
having installed a few clutches thus far i have never run into that problem at all. Specially if everything is adjusted right and the pedal as well. From any brand or design. You would think that the people who make the clutches factor in the factory design especially by now in order to not have a problem like that. Unless it was installed wrongly.
But what i am thinking is one of the following. Either the part or parts are defective or somewhere along the lines there is a small leak that causes a loss of psi. I would Rebleed the system top and bottom and then road test it to make sure.
I mean he states himself that "all his break fluid leaked out"....So the # 1 thing to do is narrow down where the leak is coming from.
Who installed the clutch anyway? you or a shop?
And btw is your car running over 700 whp? because i think that is what those clutches are designed for, am i right?
http://www.lmperformance.com/spec.asp
well actually Bryan, you were right. The piston comes out too far when the clutch is pressed and that's how the seal is broken, well that's what I was told. So i think we're going to have to adjust the stopper behind the clutch pedal so that the piston does not come out so far.
My dad's shop installed the clutch, and is doing all the repairs. My car is far from 700whp, but I plan to go FI soon and I needed a new clutch, so I purchased this one.
This is the install sheet for our twin disc, this may not be the same procedure and specifications as what SPEC will recommend but this should give you some idea what to look for in terms of travel and stop-point.
Z1 Twin Disc Install Guide
Failed me again on Saturday. Didn't open up the transmission yet, but that same thing occured. Lost pressure in my clutch pedal, and brake fluid started leaking from the transmission. This is getting so annoying. I'm really considering switching back to OEM :-\
Damn, that sucks man. Did you install a pedal stop after the last failure? The factory stop doesn't have enough adjustment on it to effectively limit the travel on a twin plate from our experience.
