Gas Hatch Issue???
Old Nov 10, 2003 | 05:46 AM
lascala26's Avatar
lascala26
Default Gas Hatch Issue???
Has anybody out there had issues with the gas hatch not opening? I need to hit my button 5-10 times to get the hatch to open. I have tried even holding the button down for a several seconds, but no luck. Last night it took 15 minutes and at least 50 pushes before it worked. The car is going to the dealer this week, but I was curious to know the if anybody else had this problem. BTW, this happens at any temperature (cold and warm). Thanks!
Old Nov 10, 2003 | 05:53 AM
jesseenglish's Avatar
jesseenglish
Yeah, it's happening to a lot of users, apparently you can adjust the gas door hinge, but I haven't bothered yet.
Old Nov 10, 2003 | 10:26 AM
jackwhale's Avatar
jackwhale
Jesse: I also have this problem. began when the weather got cold. How do I 'adjust the gas door hinge'?
Old Nov 10, 2003 | 10:32 AM
jleighZ's Avatar
jleighZ
I've had the problem since I had the car, I'm having the dealer look at that this week while my car is there. I had to hit the button 7 times yesterday before it would open.
Old Nov 10, 2003 | 11:16 AM
ChrisMCagle's Avatar
ChrisMCagle
Default Door locked
I too have had this problem, but yesterday that when I was pushing the button, the doors were locked. I got out and checked and the gas door was still shut. I then went back and pushed the button once and then looked at the gas door and it was open. Apparently the doors have to be unlocked for the gas door to open. I haven't tried it again, but will today when I get home.
-Chrismcagle
Old Nov 10, 2003 | 04:42 PM
MyZ4U2C's Avatar
MyZ4U2C
I have a problem with my trunk not opening on the first try either with the remote or the button on the trunk.
Old Nov 10, 2003 | 05:45 PM
lascala26's Avatar
lascala26
My buddy (base Z, Lemans Sunset) says to make sure the gas cap strap is not in the way of the latch when closing the hatch. Makes sense. Try it!
Old Nov 10, 2003 | 10:26 PM
ares's Avatar
ares
Veteran
lubed and adjusted, I know many have to hit it twice including me, I just punch it twice real quick and it always opens.
the button is momentary tho, holding it wont help, nor will pushing it harder or faster, hear stories of the button going through the dash, heh easy there hulk.
Old Nov 11, 2003 | 05:01 AM
FrankieZZ's Avatar
FrankieZZ
Only one thing works , have been saying this for almost a year now . Get some WD40 and lubricate the little black lever that releases the hatch and it will work everytime . Work the lever in and out several times with your finger after lubricating . That is the problem ! It needs to be done every 2-3 weeks but it will then open reliably ! Not sure , but the lever may be too wide for the opening it goes in and out of, or the material the lever is made of has a high coefficient of friction . It does need to be changed , but in the meantime if you lubricate it , you'll have no more problems !
FrankieZZ
Old Nov 11, 2003 | 06:45 AM
lascala26's Avatar
lascala26
Thanks Frankie!
Old Nov 11, 2003 | 08:35 AM
ares's Avatar
ares
Veteran
if that does work, a thicker more gel like grease might do better than WD40 in durability. just so you dont have to do it every 2 weeks or whatever, I only fill the car up every 2 weeks.
Old Nov 11, 2003 | 10:13 AM
FrankieZZ's Avatar
FrankieZZ
Ares , sounds like a good longer term alternative . Either way , this is the issue and the WD40 does work for now .
Old Nov 11, 2003 | 01:40 PM
vics350's Avatar
vics350
Frankie, where have you been. Check your PM.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
