Question
Old Feb 5, 2013 | 04:37 PM
Kris T.b's Avatar
Kris T.b
Default Question
Hey im newer buyer to the Z family, i had to rebuild mine in my post.
My i have the BASIC 350z, like no cruise control. now im stumped by something.
I understamd that most 350z have a traction control.
But mine doesn't have an on/off button.
Does this mean, that .
A- it's always on?
B- it's always off?
C- gotta find the Fuse to take it off?
For some reason when i was testing her on the track. to get used to the car see how it handle's... it seems that when i went to go for a "drift" it drifted, but the car wanted its way... if that sound's correct. maybe its just me not being used to the way the ca handles atm.
Comming from being r32-r33 owner, and other car's.
not to sure. help me out guys
Old Feb 5, 2013 | 05:02 PM
DavesZ#3's Avatar
DavesZ#3
If you have a base model, then you probably don't have it. What year?
Old Feb 5, 2013 | 05:43 PM
johnnyvq's Avatar
johnnyvq
I have a base model as well with no traction control. So in other words, it's always off haha.
Old Feb 5, 2013 | 06:04 PM
oldschool350z's Avatar
oldschool350z
No traction control so don't even worry about it. If it did have it the button would be on the left on the dash.
Old Feb 5, 2013 | 08:38 PM
TheWoo's Avatar
TheWoo
Not only that, but since it's a base model, you probably have an open differential, instead of a limited slip differential. Get an LSD if you want to drift with any sense of control and smoothness.
Higher trims of the 350z come with viscous LSDs, but ideally you should get a mechanical LSD.
Old Feb 5, 2013 | 08:50 PM
jomamahama's Avatar
jomamahama
yeah you don't have traction control which is why Z's have a pretty high accident rate on iihs charts
Old Feb 6, 2013 | 05:22 AM
KornerCarver's Avatar
KornerCarver
You have got to be kidding me. Learn to drive and you won't need traction control.
Old Feb 6, 2013 | 07:37 AM
samsniss350z's Avatar
samsniss350z
Put your key in, turn to acc and have a look at which lights show up on the dash.
Old Feb 6, 2013 | 01:31 PM
Kris T.b's Avatar
Kris T.b
thank's guys for the replies, its a 2008 350z btw
As for the LSD. what prices im i looking at? taht 1 wheel peel **** aint cutting it.
Old Feb 6, 2013 | 01:50 PM
Jah70's Avatar
Jah70
Traction control is not on your particular model so you won't have to worry about it. And when you say when you went to "drift" but it drifted and had it's own way, it's your car probably under steered since our cars are step up to under steer rather than over steer. In other words, your Z is a little tricky to drift.
Old Feb 6, 2013 | 02:02 PM
Kris T.b's Avatar
Kris T.b
like i said im not used to the car yet, so was most likely me. i just thought ide ask, the question to make sure
Old Feb 6, 2013 | 02:40 PM
jomamahama's Avatar
jomamahama
No, it's true:
http://www.autonews.com/apps/pbcs.dl...#axzz2KAJSfr70
Last edited by jomamahama; Feb 6, 2013 at 02:42 PM. Reason: added my quote for clarity
Old Feb 6, 2013 | 02:59 PM
KornerCarver
I believe that article is referring to electronic stability control, not traction control.
Old Feb 6, 2013 | 05:00 PM
TheWoo's Avatar
TheWoo
Mechanical LSDs usually run from $800-1200 depending on condition, plus labor costs in getting it into your car's rear pumpkin. If you want a price-conscious upgrade, you could swap in the whole pumpkin from a 2007+ G35/G37 or 370z. You'll get an okay VLSD with slightly lower gearing, to better break loose your tires, and it should be less than $300 depending on where you shop.
This thread delivers on the above swap: https://my350z.com/forum/engine-and-...z-3-538-a.html
It's true that the 350z comes slightly prone to understeering from the factory, but nothing that stiffer rear sway bars can't fix. Get the LSD first though.
Old Feb 10, 2013 | 07:59 PM
jomamahama's Avatar
jomamahama
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
