Abs/slip/vdc lights all on:(
Old Nov 16, 2014 | 04:19 PM
jerseytaylor's Avatar
jerseytaylor
Default Abs/slip/vdc lights all on:(
Guys I need your help. We were tucking the remaining side headlight harness (driver side) and
put everything back as it was except obviously tucked. All sensors and clips are tight.
Only problem is now the lights are all on in the gauges. Brake fluid/pads check out as well. Car runs and pulls normally. Tried resetting the Ecu Unplugging the battery and pumping the brakes. Nothing.
Anything?
Old Nov 16, 2014 | 05:40 PM
oldschool350z's Avatar
oldschool350z
I had this happen once after my battery was unhooked for storage. The slip/vdc and all other lights came on, also my rev gauge went down to 0 but the car was fine.
I reset the ECU and never had a problem. If you had the battery unhooked then it could have been something similar.
Old Nov 16, 2014 | 06:25 PM
jerseytaylor
Originally Posted by oldschool350z
I had this happen once after my battery was unhooked for storage. The slip/vdc and all other lights came on, also my rev gauge went down to 0 but the car was fine. I reset the ECU and never had a problem. If you had the battery unhooked then it could have been something similar.
yeah I had the battery removed tucking the harness the runs from it as well. Forgot to mention that. It's the weirdest thing.
Did you reset your Ecu by way of pumping the brakes and unplugging the battery as well?
Old Nov 17, 2014 | 07:15 AM
1973camarolt's Avatar
1973camarolt
Check the ABS fuse and the wide gray plug by the ABS block. People disable the VDC this way so they can drift, and it normally turns on those same lights.
Old Nov 17, 2014 | 07:22 AM
oldschool350z
I reset my ecu with unplugging the battery but also cleared the code with a obdii scanner.
Old Nov 17, 2014 | 08:34 AM
jerseytaylor
will do
Old Nov 17, 2014 | 08:35 AM
jerseytaylor
will these lights on throw codes at all ? Always thought they wouldn't
Old Nov 29, 2014 | 08:27 PM
Vax-'s Avatar
Vax-
most common problem for that is low brake fluid level.
had it personally on 2 separate nissan vehicles.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
