Slip! Slip! Slip!.....
Old Feb 14, 2004 | 09:41 AM
FB-350's Avatar
FB-350
Default Slip! Slip! Slip!.....
driving home from getting my 15k service done at the dealer, while getting onto the expressway on-ramp, the SLIP light comes on - it flashed like 3 times and it seemed like i lost power...WTF?
i wasn't going excessively fast, i.e. i wasn't on the limit of the cars handling ability so i'm trying to figure out what happened?
my car has no suspension mods, only wheels....
ANYBODY?
thanx.
Old Feb 14, 2004 | 09:58 AM
orhanz33's Avatar
orhanz33
what size wheel + tires do you have? were you flooring it?
Old Feb 14, 2004 | 10:06 AM
FB-350's Avatar
FB-350
out back, 20x10 w/ 275/30, up front 20x8.5 w/ 245/35....
i was not even close to flooring it, just cruising along getting into the on-ramp - maybe 45-55 mph....
Old Feb 14, 2004 | 10:12 AM
ZGuy's Avatar
ZGuy
You have to maintain the same overall tire diameter RATIO from front to back or else the VDC will think a tire is slipping. Have you checked the new sizes?
Old Feb 14, 2004 | 10:17 AM
FB-350's Avatar
FB-350
i've got the enthusiast model - is the VDC standard on this model?
i also remeber reading somewhere that if the TCS system is off, then it won't be a problem... the TCS was on when this happened...
no i didn't check the overall diameter; i know of a number of other Z's that run this size - i wonder if they've run in to this issue also??
Old Feb 14, 2004 | 10:50 AM
Z-Z's Avatar
Z-Z
This happened once to me as well. I was driving normally and accelerating (not hard) getting onto the freeway. I figured that I musat have hit some loose gravel or somthing. I have an Enthusiast with stock wheels and tires, and the TCS was on.
Old Feb 14, 2004 | 11:39 AM
ares's Avatar
ares
Veteran
your size look off to me. though Im not familiar with 20" rim sizes, but I would have guessed you need 30series front and back. as it stands your fronts are larger than it thinks.
it will cause the VDC to kick in whenever the SLIGHTEST loss of traction occurs, little sand in the road or even a turn that gets the wheels moving at different speeds like an on ramp.
Old Feb 14, 2004 | 03:19 PM
FB-350's Avatar
FB-350
thanx guys... a least i know i'm not the only one...
i figure i will just drive with the TCS off from now on... i'll only use it when it's raining or something...
Old Feb 15, 2004 | 10:45 AM
little_rod's Avatar
little_rod
Well, I have my stock wheel/tire package on right now, and I get alot more of the slip light. I think it is a little cause the tires have less grip in the cold of winter. But I do get the light, and sometimes I have no idea why.
Old Feb 15, 2004 | 03:58 PM
grifferjr's Avatar
grifferjr
i get this everynow and then also at times wheni am no where near the limits of the car. i read where there is a flywheel recall on some 2003 Z's and the description for the recall sounds something like this. when i checked the vin numbers on the recall mine is a later number. its the early ones that are being recalled. could this be the culprit?
Old Feb 15, 2004 | 05:19 PM
fuzion's Avatar
fuzion
just yesterday i had this happen to me as well. as with all of you, i was not going fast - around 30-40 then i saw the light blink a few times rapid - dont believe i ran over and ice/gravel - also cut power.
04 enthusiast model, tsc was on.
seems to be a fairly common problem......doesnt bother me that much, though.
Old Feb 15, 2004 | 06:01 PM
ZPower's Avatar
ZPower
Just shut it off.
Old Feb 16, 2004 | 03:58 AM
ACP's Avatar
ACP
that size he has is what is recommended for 20's
That is the sizes I run (except 285)
Very very close to the stock sizes
Have no issues with the VDC light, unless I romp on it, and the Twin Turbos make my tires spin
Old Feb 16, 2004 | 06:37 PM
mrrrkva's Avatar
mrrrkva
I have an entusiast as well, stock tires, stock wheels. I notice this as well. MAYBE 1/4 acceleration, last few times.
Old Feb 16, 2004 | 08:21 PM
jairogarcia's Avatar
jairogarcia
Hey FB-350 I used to drive with the TCS off until I had to punch it once to get on the freeway. I lost control of the car and almost hit the center divider.
Old Feb 16, 2004 | 08:36 PM
Jsn350Z's Avatar
Jsn350Z
You say you have a 35 profile in the front? A 30 is the proper size.. However I am not sure if the wrong sizes in the front can effect TCS/VDC?
Old Feb 16, 2004 | 08:59 PM
little_rod's Avatar
little_rod
So you "had" to punch it. Gotta love that. What magical force made you have to punch it.......
Old Feb 17, 2004 | 10:21 AM
BlackNissan350z's Avatar
BlackNissan350z
is you speedometer and tcs run off the front wheels or the rear wheels, i would expect the tcs to be on the rears but the speedo im not sure about
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
