Official vinyl wrapping thread.
#161
Actually expected to see my thread merge into this one. Didnt really see any info on "how to" so I made a separate thread for more attention.
keepin' forums clean
thanks for all the info sparco...seriously helpful, even with all the searching around Iv done, along with talking with shops. Yeah, even with all that money I threw away at my 350z in 2009 I didnt go with a dry carbon, you definitely want purpose when dropping all that cash for one.
My thought as of last night is I will wet sand and prime it. Now Im just waiting to hear back from some shops to see if they will actually give me a little help with the type of primer I should use and if I can actually do it myself with proper tools.
Read a bit on spraying, painting and rattle canning primer methods. Obviously spraying would be my best bet, its just a matter of tool cost and if it would just be cheaper to get a shop to wet sand and prime it.
You have some options: You could sand it then clearcoat, or primer and paint, or primer and wrap.
Those "cf" hoods are actually just fiberglass with a single layer of carbon for aesthetics. Real carbon fiber hoods are made with dry carbon and all layers being carbon with proper resin:composite ratio. Those are generally in the 2k+ price range. I've only seen a couple of members on here with true dry carbon pieces in the last 10 years.
#164
^^Reminds me of my old 350z...a lot!
Was the kit already painted before you wrapped it?
http://farm3.static.flickr.com/2706/...cc341ab9_o.jpg
craig12895 (05-11-2016)
#167
air compressor and all accessories
spray gun with 2mm tip (Harbor Freight has great cheap ones)
you can use Speed Prime or the better stuff 2 part epoxy primer
sand paper
masking paper and tape
respirator
Cost ~ $700-1000.
**I would not use rattle can. Doesn't adhere as well as the autobody stuff.
zerafian (05-11-2016)
#168
#169
DIY You'll need:
sand paper
respirator
Cost ~ $700-1000.
sand paper
respirator
Cost ~ $700-1000.
looks like it will run me $500-1000 to fully prep for vinyl going by a couple shops. Spoke with my complex as well today and they said if they see me doing anything like painting in my garage they will revoke my garage rental...seems like things are working out to where I have no choice.
rustyschopshop (05-17-2016)
armt350z (05-18-2016)
