Sponsored by:
Sponsored by:
350z
Old 04-20-2017, 04:36 AM
ajmacera
ajmacera's Avatar
Default 350z
Im looking to buy a used 350z with around 100k miles on it, and do you think I would be buying a safe car? or one that will blow up on me in a year. It will be daily driven
Old 04-20-2017, 04:50 AM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
nobody can answer that.... it depends on how well the previous owner took care of it
Atreyu'z 350 (04-20-2017)
Old 04-20-2017, 05:32 AM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
It might be worth your time and $ to have a mechanic do a 1hr inspection to look at brakes, bushings, compression and overall health. I wouldn't buy a 10yr old car simply off a test drive.
Old 04-20-2017, 06:19 AM
dcains
dcains's Avatar
This is one of the nicest used Z's I've seen around here for a while. No personal interest, and I don't know the seller:
https://tampa.craigslist.org/hil/cto/6093477487.html
Old 04-20-2017, 09:16 AM
PerfZ
PerfZ's Avatar
I've got 158,000 on my '03 and it still runs like a champ, although it does burn a quart of oil every 2500 miles or so. Been fairly maintenance free for 14 years now....
Old 04-20-2017, 04:24 PM
Spike100
Spike100's Avatar
Get the maintenance records for the car. If the previous owner(s) has been diligent changing oil and following recommended maintenance procedures, you're good for at least another 75K miles.
You might need to replace some sensors (crankshaft, camshaft, and oxygen) at around the 100k mark, and the clutch is probably getting close to wearing out.
Look closely at the body for signs of rust. Rust is difficult and expensive to repair. If you see any rust, forget this one and look for another car.
Old 04-21-2017, 06:24 AM
JERZ350
JERZ350's Avatar
Good find, good price for the condition.
Old 04-21-2017, 06:41 AM
iideadeyeii
iideadeyeii's Avatar
Great pictures for selling a car, NOT!!!
Atreyu'z 350 (04-21-2017)
Old 04-21-2017, 02:46 PM
Atreyu'z 350
Atreyu'z 350's Avatar
Heh.. Those are teasers to get you to call the guy, but they're not working.
Old 04-21-2017, 03:09 PM
Atreyu'z 350
- Make sure the title is clean.
- Check the Carfax. (if any)
- Ask for vehicle maintenance records from previous owners. (if any)
- Get on the ground, remove the splash guard and check for leaks and anything out of place.
- Start it and listen for abnormal noises.
- Drive it and listen/feel for abnormal noises/vibrations. Things should operate smoothly and deliberately.
- Go home and think about it. Do some research on the car.. Anything and everything. It's all out there.
- lol.. as far as blowing up. No, it won't blow up. As long as it was properly maintained up until this point, but there's no way of knowing that without maintenance records.
go1f17
11-13-2016 02:16 PM
Spork56
10-18-2016 09:10 AM
JROCars
10-04-2016 04:32 AM
Quick Reply: 350z
