Help - camshaft sensor changed and throwing codes
Old Sep 30, 2017 | 02:56 PM
Amanda VanVlack's Avatar
Amanda VanVlack
Default Help - camshaft sensor changed and throwing codes
I had the check engine light, TCS, and slip light come on. I took it and had code read. Showed bank 2 camshaft sensor. I have changed it twice and had code erased both times. All lights go off as soon as you start it after resetting it but the next time you start it they are back on. What could it be besides the sensor that would throw the sensor code?
Old Sep 30, 2017 | 07:21 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Are you using an OEM part? Sometimes aftermarket electrical parts fail...
Old Sep 30, 2017 | 09:16 PM
oldschool350z's Avatar
oldschool350z
Have you tried to reset the ecu? Sometimes that can solve some issues. I had some code after storage and reset the ecu it stayed off.
Old Oct 1, 2017 | 02:10 AM
Amanda VanVlack
[QUOTE=dkmura;10918069]Are you using an OEM part? Sometimes aftermarket electrical parts fail...[/QUOTE
Yes OEM part
Old Oct 1, 2017 | 02:13 AM
Amanda VanVlack
First time changing I had a friend erase the code. Second time we disconnected the battery. Was told by O'reillys that would erase the code
Old Oct 1, 2017 | 06:04 AM
Atreyu'z 350's Avatar
Atreyu'z 350
An electrical short in the wiring going to/from that sensor. Check the course of the wiring and harness for damage... What was the actual code anyway?
Old Oct 1, 2017 | 08:38 AM
i8acobra's Avatar
i8acobra
What was the code? Also, because I've seen people mix them up, you changed the driver's side, right?
twoey2340
Dec 17, 2023 12:19 PM
TheFlyingTosher
Apr 9, 2017 12:09 PM
Nickz_33
Feb 1, 2017 02:12 PM
Malpractice
Nov 19, 2016 07:17 PM
561350z
Oct 26, 2016 04:01 PM
