Dead Battery. No Crank...
Old Dec 21, 2017 | 03:16 PM
CK_32's Avatar
CK_32
Unhappy Dead Battery. No Crank...
Ok so last night I was working on my turbo and accidentally left the key in the on position for about an hour. Car is dead.
But now it will not crank over. We hooked a jumper pack to it. I have it connected to another car right no and nothing. 14v and nothing. No clip, no attempt nothing.
I don't see any blown fuses. BUT the car will push start it self if I roll and pop it in gear. So it cant be NATS. I ran system codes and no codes. All dash lights work and function, injectors prime. Everything works accept the actual starter.
Wtf could make it no engage the starter at all, but push start from a dead battery? If it is the starter how does it die from a dead battery?
Im really confused on this one.
All I did was take my turbo off and some of the exhaust sections. Other than that I didn't touch a thing.
Car is running weird when its on too. B1 is normal 14.5 AFR.. But rank 2 idles at 13.2 ish....
Old Dec 21, 2017 | 03:49 PM
Atreyu'z 350's Avatar
Atreyu'z 350
Try swapping a known working battery in from another car with the same terminal connections and see what happens.
Old Dec 21, 2017 | 04:19 PM
HOMiEZ's Avatar
HOMiEZ
Yeah if you haven't already its worth trying another battery. If the battery is drained enough it could be having trouble holding enough charge to crank.
Old Dec 21, 2017 | 05:12 PM
CK_32's Avatar
CK_32
But having the jump pack and having the other cars connected to it should replicate that. Especially when hooked up the volts show 14v
I mean I could try but that doesn't explain why the starter isn't even cranking and all my gauges are running.
Old Dec 21, 2017 | 06:48 PM
Atreyu'z 350
I'm willing to bet that the anti-theft system kicked in.. my bad. missed the bottom part that's it running weird..
Old Dec 21, 2017 | 07:42 PM
icer5160's Avatar
icer5160
Which part of the exhaust system were you working on? I'm guessing very close to the headers since you mention taking off your turbo, but want to double check. The starter motor itself is located on the passenger side of the bell housing, very close to the exhaust header & downpipe/cat coming off bank 1. I recommend double checking all the wiring going to the starter. There should be a direct feed from the battery to the starter. The starter itself I think reaches ground through the block, so make sure all your engine ground connections are still solid!
If you had to disconnect a grounding strap on the engine to reach your turbo or exhaust, it's very easy to miss or forget when putting things back together.
Good Luck!
-Icer
Old Dec 21, 2017 | 09:36 PM
CK_32's Avatar
CK_32
Yup that's exactly where I was. Dam it I gatta get back under there.
I did disconnect one clip plug but I put it back in right after. I'll go and check. I didn't know it had wiring down that way tho.
Old Dec 22, 2017 | 11:53 AM
CK_32's Avatar
CK_32
Well it would help if you plugged in the starter clip wire....
Swore I plugged that little sht back in. Fixed.
Old Dec 22, 2017 | 01:07 PM
Atreyu'z 350
Good stuff. Glad you figured it out.. I was rendered useless after 8pm yesterday anyway.. Vodka eggnog.. Peer pressure's a bish.
Old Dec 22, 2017 | 01:47 PM
zakmartin's Avatar
zakmartin
CK - did you try plugging in the starter clip wire?
Old Dec 22, 2017 | 02:17 PM
Atreyu'z 350
..that just MIGHT be it.
Old Dec 22, 2017 | 02:27 PM
zakmartin's Avatar
zakmartin
Old Dec 23, 2017 | 11:59 AM
travlee's Avatar
travlee
Master
Blinker fluid wasnt holding a charge.
dont ya hate when you think you checked everything but didnt. Did it many of times myself
Old Dec 23, 2017 | 02:04 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
I've made very few mistakes in 40+ years of wrenchin' around. I'm that good. Maybe 30-35 times is all. Hey, that averages less than once a year. (And of those, the first 30 or so occurred in the first couple years between ages 15 and 17. Heh heh.) Biggest blunder besides the "three days to reinstall the tranny cuz I was being 'toopid and 'tubborn" was when I just couldn't quite get the last ounce of lube in whilst re-packing my muffler bearings.
But yeah, if one NEVER makes a mistake working on a car, you're not working on a car. Paper cuts from the credit card receipt doesn't count either.
Old Dec 23, 2017 | 02:42 PM
travlee's Avatar
travlee
Master
You took caitlyn jenner in and out of your car?
Old Dec 23, 2017 | 03:03 PM
MicVelo's Avatar
As soon as I typed the word, I knew I was in trubbo.
Juztin
VQ37HVR
Mar 3, 2014 01:32 PM
skaterbasist
Apr 21, 2007 07:50 PM
NiSmO21z
Mar 4, 2006 01:38 PM
