Need a little professional help.
Old Jan 7, 2018 | 06:19 PM
Moe Dib's Avatar
Moe Dib
Default Need a little professional help.
Hey guys so i have one question and the question is as follows;
Can/should the “service engine soon” light come on if someone replaces the clutch on a 350z? It’s a 2003 if that matters in anyway. Thanks to anyone that helps!
Old Jan 7, 2018 | 06:23 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Sure it can - lots of stuff that could trigger a CEL - but until you pull the DTCs, no way to tell what got messed up during the clutch work or if it was just a coincidence.
Old Jan 7, 2018 | 06:25 PM
Moe Dib's Avatar
Moe Dib
You mind private messaging me your number so i can text you? I need A little bit of help and i need it asap if you do i really Appreciate it man
Old Jan 7, 2018 | 08:10 PM
bealljk's Avatar
bealljk
scan the code ... report back
Old Jan 7, 2018 | 08:36 PM
CK_32's Avatar
CK_32
Like above it's a CEL, pull the code and go from there.
With out that it's literally a shot in the dark 10x
Old Jan 7, 2018 | 09:49 PM
Moe Dib's Avatar
Moe Dib
I gotcha i will get the code but would that engine light come on if someone replaced the clutch and didn’t mess anything else up?
Old Jan 7, 2018 | 09:50 PM
Moe Dib's Avatar
Moe Dib
Old Jan 7, 2018 | 10:15 PM
CK_32's Avatar
CK_32
Yes.
It says engine light but CEL is for almost anything the ECU can detect on the vehicle. Including engine, transmission, ABS and fuel system.
Old Jan 8, 2018 | 04:36 AM
BQPham's Avatar
BQPham
As the others already stated, it surely can, but without specific info on the codes we can't give a real idea of what it is. It could be something as dumb as an O2 sensor not being plugged in all the way, gas cap not being closed (doubt they opened it), etc. I imagine they dropped the exhaust so the O2 sensors were definitely touched or unplugged.
Old Jan 8, 2018 | 05:18 AM
iideadeyeii's Avatar
iideadeyeii
No, it shouldn't normally go on unless something is unplugged. Why are you all saying yes?
Old Jan 8, 2018 | 05:44 AM
Atreyu'z 350's Avatar
Atreyu'z 350
OP. Is the car starting and driving normally after this clutch install? Was the car starting and driving normally before this clutch install?..
Old Jan 8, 2018 | 06:40 AM
MicVelo's Avatar
Key word is "normally". Like others have noted (incl myself), it's not that the clutch itself would/could trigger a CEL/code, more like something in the process of changing the clutch may have faulted the system, e.g., wire loose/unplugged an O2 sensor or somesuch.
We should just wait and see what code pops up if anything before speculating, of course. Like I said, could just be a coincidence it came up and no cause/effect resulted from the clutch work.
Old Jan 8, 2018 | 10:53 AM
Moe Dib's Avatar
Moe Dib
Well yes the car is starting and driving with no problem
Old Jan 8, 2018 | 10:54 AM
Moe Dib's Avatar
Moe Dib
Alright thanks And thanks to everyone else that is trying to help I will update you guys with the codes as soon as I can
Old Jan 8, 2018 | 10:57 AM
deeliciousqueen's Avatar
deeliciousqueen
It is the flywheel not properly aligned to the engine, the FW have notches that needs to be aligned to the dowel on the crank. The codes will show you readings that relates to cam positioning sensor, the reason is really the flywheel alignment. I have personally dealt with this and found the answer using the search function. Thank me later.
Old Jan 13, 2018 | 04:15 PM
Moe Dib's Avatar
Moe Dib
I scanned The car and it says camshaft position sensor circuit malfunction so i think You are right I’mGoing to take it to a mechanic anyways of course. Just need to wait until Monday. Thank you!
turismo
Photography
22
Apr 17, 2007 04:37 PM
ZYAL8R808
Jul 30, 2004 02:11 AM
XBS
Mar 12, 2003 03:19 AM
