350z does not reconize the gear i am in
Old Feb 4, 2018 | 07:41 AM
supremeZ's Avatar
supremeZ
Default 350z does not reconize the gear i am in
Hi there i am kinda stuck on this one but my 2004 Automatic 350z doesn't reconize that it is in park or neutral. Normally where it shows the gear your in on the dash it is blank like the car is not in any gear any suggestion on what it maybe?
Old Feb 4, 2018 | 10:30 AM
CK_32's Avatar
CK_32
Check your fuse of the sensor thats non your transmission that reads that. Or check to make sure the sensor isn't broken.
Old Feb 5, 2018 | 07:16 AM
supremeZ's Avatar
supremeZ
If You don't mind me asking where would that fuse/sensor be located?
Old Feb 5, 2018 | 01:12 PM
CK_32's Avatar
CK_32
Either under your hood by the battery or by your pedals to the left. I'd assumE the one you need is in the interior kick panel fuze box.
The sensor should be here
Old Feb 6, 2018 | 12:30 AM
supremeZ's Avatar
supremeZ
I believe the trans that you showed me in the picture above is a MT if i am mistaken please correct me because my 350z is auto (unfortunately) and i cant seem to find the said sensors. Not to mention the transmission that u showed seems to look like a z32 trans not a z33 but i maybe mistaken
Old Feb 6, 2018 | 01:08 AM
supremeZ's Avatar
supremeZ
Question
i think it might just be a power issue
Old Nov 1, 2021 | 08:33 PM
Re6per's Avatar
Re6per
Default Solution?
hey I’m having the same problem did anyone figure out the problem. ?
Old May 14, 2025 | 06:14 PM
Zamwich's Avatar
Zamwich
hey I’m having the same problem, did you figure it out, if so what was the issue, I’m starting to think I might have a bad ecm
BigBalls
Jul 16, 2012 07:55 AM
love_350z
Oct 4, 2005 10:02 AM
neel6690
Aug 11, 2005 01:29 PM
Swank
Mar 11, 2003 02:42 PM
BENCH
Nov 9, 2002 03:46 AM
