Sponsored by:
Sponsored by:
Long tube headers
Old 06-01-2018, 11:08 PM
Siqcology
Siqcology's Avatar
Default Long tube headers
Hey guys. I just bought some long tubes from ISR. My factory o2 sensors do not reach. Is there anyone that sells extenders. Or had anyone cut and added wire to their o2 sensors to make them longer?
Old 06-02-2018, 02:48 AM
BluestreamDE
BluestreamDE's Avatar
I run the OBX-R long tube headers, I had to cut and solder the wiring with about 6 inches of wire each to extend the length to reach the o2 port. It's easy.
Old 06-02-2018, 09:12 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
I had to cut and solder for my PPE header install
Old 06-02-2018, 09:20 PM
06platinumG
06platinumG's Avatar
My PPE came with extenders. You might contact them to see if they sell separately
Old 06-07-2018, 05:52 PM
Siqcology
Siqcology's Avatar
As figured everyone’s answer was about the same about extending. I plan on extended it myself. Should I extend it from the sensor or cut the engine wiring harness and extend that?
Old 06-09-2018, 04:47 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
I would extend the sensor side, once you cut your harness theirs no going back.
I used some crazy box connection on mine, if I remember correctly they need some air flow around then or something.
Don't know if you can tell from the pic but theirs some big *** box connectors on my 02 sensor wires.
Old 06-09-2018, 04:50 AM
dboyzalter
dboyzalter's Avatar
This is what I used.
Old 06-09-2018, 01:52 PM
Siqcology
Siqcology's Avatar
https://youtu.be/ex1Hki6-NHw
sounds good. I assume cutting the engine wiring harness would be bad and it would be better to cut the o2 sensor and extend the wires!
zheka911@hotmai
07-27-2011 07:45 AM
jeffw
10-29-2003 08:38 AM
VQ35DES
10-07-2003 02:50 PM
07-31-2003 06:24 PM
dougrace zs
03-19-2003 04:23 PM
Quick Reply: Long tube headers
