Car pulls to right
Old Jul 10, 2018 | 06:13 PM
Tomypasta's Avatar
Tomypasta
Default Car pulls to right
My 350z has just 39000 miles and is all stock with 17 inch wheels new tires and no accidents. The car pulls to the right and the faster I go the more it pulls. I had a alignment done and the shop told me they gave it as much adjustment as they could but it still pulls. Does anyone know if this is a known problem on the 350z and what to do to correct it. Thanks in advance.
Old Jul 10, 2018 | 09:46 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Not a "known" problem per se (unless car was damaged)
Main causes for pull:
- Alignment off
- Tires unevenly worn or pressures off
- Brake drag (from wear or stickiness in caliper)
- Suspension/steering components worn
Suggest you baseline all of the above and if that doesn't cure it, take it to a shop who can do a full front end inspection/alignment.
Old Jul 22, 2018 | 05:02 PM
delco7's Avatar
delco7
Default Radial tire lead
Try crossing the front tires and if it pulls the other way....there ya go......BAM! You may need to have the alignment reset to factory specs. Somewhat odd the shop said they "Gave it as much adjustment as they could" Any F/E man worth his salt is only going to set it to where it should be. You can't correct radial tire pull with caster adjustment. That would really just make it a bigger mess. In the olden daze, you weren't supposed to run radial tires backwards, but now it shouldn't matter.
Delco
Old Jul 22, 2018 | 06:05 PM
Tomypasta's Avatar
Tomypasta
The front end guy said he turned the adjustment as far as could go and couldn't get it into specs.
Old Jul 23, 2018 | 08:34 AM
delco7's Avatar
delco7
Default Specs
Well then clearly something is bent. I would venture a guess and say it was curb checked. Strut and/or lower control arm/frame. Find a new F/E man. If you run out of adjustment, something's bent or worn badly, and with 39k it probably isn't worn. He shouldn't have tried to adjust for a bent part. Just sayin'.
Old Jul 23, 2018 | 09:26 AM
iideadeyeii's Avatar
iideadeyeii
Sooo there's your answer
Old Jul 23, 2018 | 10:10 AM
terrasmak's Avatar
Post the alignment sheet
Old Jul 23, 2018 | 11:10 AM
Tomypasta's Avatar
Tomypasta
Sadly I didn't get one
Old Jul 26, 2018 | 03:51 PM
Spike100's Avatar
Spike100
Something is very wrong here:
  • It is unusual for a shop to do an alignment and not provide a spec sheet.
  • If a shop cannot align the car (as they stated in your case), they should offer a solution.
Old Jul 26, 2018 | 04:45 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
No accidents that you know about. If its all stock and no accidents with 39k miles no reason it would pull to the right.
Theirs not much up front to adjust other than the tie rods.
HINZIR
Sep 20, 2007 05:37 AM
jsupetran
Oct 22, 2006 05:31 PM
Ghettorab
Feb 21, 2004 07:55 PM
all_bark
Jul 21, 2003 04:49 PM
