Sponsored by:
Sponsored by:
Motordyne tdx2 help
Old 10-31-2018, 07:30 AM
That_hrz
That_hrz's Avatar
Default Motordyne tdx2 help
Anyone running motordyne tdx2 that rattles at the mid muffler if so how did you fix it? I have the older version tdx2 but purchased a new mid muffler so I can modify the old one to fit for my bp single turbo. Spoke to tony at motordyne he told me the newer generation is slightly different because of the inlet flange angle. Only thing that seemed to resolve the issue alil was flipping the mid muffler upside which I think still clears the driveshaft.
Old 10-31-2018, 07:42 AM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
Mine used to hit the m brace , i got a piece of rubber exhaust hanger and wedged it between the resonator and brace
Old 10-31-2018, 07:57 AM
That_hrz
That_hrz's Avatar
Figured I would have to do something like that thanks
Old 10-31-2018, 08:06 AM
travlee
Master
travlee's Avatar
You could loosen all the vbands, place something on the m brace holding the resonator up, and then retighten everything. That worked for me once and gave me about 1/2 inch clearance
Old 10-31-2018, 08:26 AM
deeliciousqueen
deeliciousqueen's Avatar
Can someone post a pic of what you did? mine is hitting the rear sway bar, if I twist it the other side, it will hit the diff.
Old 10-31-2018, 08:27 AM
That_hrz
That_hrz's Avatar
Tried that and got some clearance now the resonator is what’s not centering correctly it’s more to the right side and rubbing up against the underbody. I’ll take off the y pipe and try again
Old 10-31-2018, 08:29 AM
travlee
Master
travlee's Avatar
flip.the pipe around....make sure it isnt backwards
Old 10-31-2018, 08:33 AM
travlee
Master
travlee's Avatar
stock cats or what?
Old 10-31-2018, 12:18 PM
deeliciousqueen
Already did that still hitting one or the other, I hear occasional rattle now which I suspect hitting the rear sways where before I flipped it was hitting the ear of the diff. Here is the thread with pics.
TDX2 fitment issue
Old 11-02-2018, 06:35 AM
That_hrz
That_hrz's Avatar
stock cats or what?
I’m running art pipes
BlueDragonZ
01-15-2014 12:54 PM
mike_eee
04-04-2012 08:28 AM
Deteria
Texas
01-10-2012 10:06 AM
Jairen
12-05-2011 01:56 PM
Quick Reply: Motordyne tdx2 help
