Grinding noise video attached
Hello names Mike,
been happening for a couple days now and I can't find a solution namely because of my description of the noise doesn't really help anyone via text. Please watch the video and excuse the volume or lighting and the mess behind me Haha! Not a video editor just used my phone. Any insight would be wonderful. Thank you!
https://m.youtube.com/watch?v=ZZguKPvuyYo
Sounds like it could be a failing pulley, or bearing attached to one of the peripherals, such as the alternator, etc...
You could take the belt off, and try to spin some of the pulleys by hand, to see if you can produce the sound.
yes it could be this, belt, or even something as simple as a wire or something rubbing on one of your fans. It is a bit hard to tell from the video but i would start there.
99% confident it's a bearing running off the accessory belts. As previously suggested, your best bet is to remove the belts and try each accessory by hand, if you notice any of the bearings spinning loose, that's most likely your issue. The pulley bearings should spin smoothly, but there shouldn't be any play or wobble. If it sounds or feels like a skate bearing, you got a problem.
-Icer
-Icer
-Icer
-Icer
BTW sorry for double post I don't know how to link more than two guys quotes at the same time on the phone.
I'm with Chihuahuamaster (btw that might be the best screen name) I did my serpentine last summer and immediately after got a vibraty kind of noise. Considering the parameters of the job it has to be the tensioner pulley. But the thing will be fine if you dont fix it right away.
"Somethings getting rattled. It's intermittent so I doubt it's a pulley. When the rpm's fluctuate is probably when it rattles. If it is a pulley, I bet it's the a/c clutch."
I listened again and gonna change then double down on my bet. I think it's a cat. conv. heat shield.
I've had this exact type of noise before, true it's most likely not a "pulley" but it is one of the accessories. In my personal case, the root cause was the alternator bearings. I don't know exactly why the noise was intermittent (possibly load on/off cycles), but the alternator was the culprit. Bearings can behave oddly sometimes, especially if there's an axial load put on them, for example if the belt isn't running perfectly aligned on all pulleys.
Suggestion...
Remove the outer belt first and start the engine, listen for noise. If it's gone you just narrowed down your suspects. If the noise persists, you've again eliminated the accessories running off the outer belt. That's probably one of the biggest benefits of having multiple accessory belts on an engine vs. one giant serpentine belt.
Good Luck!
-Icer
Suggestion...
Good Luck!
-Icer
evil_tt
Jun 17, 2009 08:56 PM
MIAPLAYA
Jul 21, 2005 07:09 PM
valdeztke
Mar 24, 2005 12:17 PM
