flywheel chatter? video attached
Old Dec 14, 2011 | 06:47 AM
sturman8r's Avatar
sturman8r
Default flywheel chatter? video attached
http://www.youtube.com/watch?v=ty-_F...ZY-2JE-moPLxbu
Old Dec 14, 2011 | 07:09 AM
briin79's Avatar
briin79
Just google 350z flywheel chatter. Did you install a light weight flywheel? if the answer is yes then its normal and to be expected
Old Dec 14, 2011 | 07:27 AM
Looch's Avatar
Looch
Flywheel chatter is a vibration, when the engine needs to work harder to get the car moving (2nd, 3rd, maybe 4th gear in low rpms). First, that does not sound like a vibration. I have some chatter at idle but giving it gas in neutral should not make it worse. It disappears when I touch the gas in neutral.
I do not think that is regular flywheel chatter, not sure what it is though. Somebody else chime in?
Old Dec 14, 2011 | 07:30 AM
sturman8r's Avatar
sturman8r
I havent installed anything. it is a 05 track edition with 39k miles. its started making this noise about 2k miles ago. all fluids are in check and everything is working like it should. i just cant figure out what this noise is!
Old Dec 14, 2011 | 07:35 AM
bmccann101's Avatar
bmccann101
that is not flywheel chatter at all. period.
sorry to scare you, and it could certainly be something else mind you.. it is a video over youtube..
but thats either something lose and rattling against the floorboard like the exhuast or cats.. or its a lower engine knock and the beginning of a bearing dying and ruining your engine. Bring car into a shop immediately, this is not a drive around and ask my350z.com ppl over a video..
and again, it could be nothing, but if it IS a bearing, youll thank me 100 times for catching it before it ruins your crank and sends metal thru your block killing your engine 100%.
Old Dec 14, 2011 | 07:41 AM
sturman8r's Avatar
sturman8r
ok thanks stealership here i come
Old Dec 14, 2011 | 07:54 AM
rpdrives's Avatar
rpdrives
I had a 69 Cyclone Cobra Jet making a sound like that. It turned out to be the throw out bearing. It will be interesting to know what it is. Let us know when you find out?
Old Dec 14, 2011 | 09:12 AM
djamps's Avatar
djamps
Doesn't sound like flywheel chatter to me. TBH I'm almost thinking rod knock. What happens with the clutch in?
Old Dec 14, 2011 | 09:23 AM
sturman8r's Avatar
sturman8r
it doesnt do it with rpms. i drove it around and then parked it and left it idling in neutral and it did it off and on something must be hitting. if it was rod knock or bearing it would do it consistantly wouldnt it?
Old Dec 14, 2011 | 09:28 AM
djamps's Avatar
djamps
My question is, does it still do it with the clutch depressed? If the noise stops, it could be normal. If the noise is still there, it's something wrong on the engine/flywheel side. Keep in mind the flywheel itself should never make noise, it's the transmission gears that emits the actual 'normal' noise so many refer to. That's why pushing in the clutch should stop it if it's the 'normal' kind.
My buddy's G has the same kind of sound except much worse (like rod knock but so bad it couldn't still be running LOL), turns out bearings on the input shaft of the transmission itself is F'd.
Old Dec 14, 2011 | 09:37 AM
sturman8r's Avatar
sturman8r
it still does it with clutch in and out. the thing is that when i got home from driving it didnt do it like it did in the video. it just sounded as something was loose and rattling against something else. im going to jack the car up and look to see if the exhaust is hitting. i took it to a very reputable transmission shop a couple weeks ago and he said that everything felt and looked as should when he drove it and put it on the lift.
Old Dec 14, 2011 | 10:44 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Sorta sounds like a worn out stock dual mass flywheel.
Old Dec 14, 2011 | 11:02 AM
sturman8r's Avatar
sturman8r
jacked up the car and nothing is loose or touching something else. when i get above 1700 rpm everything sounds normal again! the noise is coming from under the middle of the car cant hear it very well in the engine bay!
Old Dec 14, 2011 | 11:25 AM
sturman8r's Avatar
sturman8r
im thinking it could be a bad cat or something could have gotten loosened up in the cat because my car is so low!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
