350z Engine Hiss Sound / Burning Smell - Vacuum, Gasket, Coolant Leak? *VIDEO*
I've been noticing the smell of something burning through the vents. The smell is more noticeable on the passenger side than the driver side when I have the hood open. While I was inspecting it today I heard a "hiss" sound. Before I have a buddy check it out I thought I'd ask the forum. It sounds like it's coming from the plenum spacer. You can tell as I move the camera closer to the spacer that the hiss gets louder and more isolated: https://www.youtube.com/watch?v=Xa8P...ature=youtu.be
The smell is similar to hot brake pads but since the car isn't moving that's obviously not the cause. Since it's kinda "sweet" I figured it might be coolant leaking and burning on some hot surface. Oil is fine, not burnt and not low.
Figured it out, the valve cover gasket is leaking and oil is hitting the exhaust manifold causing smoke to rise up and then it gets sucked into the vents. Still not sure why it's hissing near the plenum, might be a separate issue. Hasn't thrown any codes and the engine runs just fine.
I'm going to just replace the whole valve cover on the passenger side since I'm having a shop do the work. According to the forum it's not a matter of if but when these valve covers fail.
I had the driver side valve cover and gasket replaced in 2016 cause it was leaking at the spark plug gasket (non serviceable). I have a 2004 with 138,000 miles.
zafarmoh
Dec 12, 2017 11:45 AM
joeyvq27
Oct 13, 2016 01:59 PM
D&G35
Feb 3, 2012 06:21 PM
