anti locks kicking in on hard cornering
Old Aug 30, 2019 | 03:32 PM
Byoungz's Avatar
Byoungz
Default anti locks kicking in on hard cornering
Hey everybody having issue with anti-locks kicking in on hard cornering. Does it with or without VDC engaged. I have no lights coming on when it happens (i.e slip or brake). It is a 2003 350Z touring. 43k miles. Off set wheels and tires. Has 14" Akebono big brake kit, slotted rotors, hawk HP ceramic pads. Only change on car prior to problem put new rear tires on, front tires running at about 6/32" tread. Run SCCA autocross. One run anti-locks threw me out past slalom cone no control. Mechanic thinks ABS control module. I question due to no indicator lights. thought to disconnect ABS. Any suggestions? Looked through many threads found nothing specific to this. Thanks for any help.
Old Aug 30, 2019 | 03:48 PM
dkmura's Avatar
dkmura
General & DIY Moderator
What size tires are you running?
Old Aug 30, 2019 | 04:06 PM
Byoungz's Avatar
Byoungz
Fronts-Pirelli P225/45 R18 91W M&S. Rear Pirelli 245/45ZR18 100Y. Is it possible you just answered my question. Rear traction pushing through front traction?
Old Aug 30, 2019 | 04:54 PM
Byoungz's Avatar
Byoungz
Do you believe the tire difference to be the problem?
Old Aug 30, 2019 | 05:05 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Not second guessing dkmura but I suspect he was looking for a VDC trigger, e.g., rear tire too short or otherwise outside the 3% window.
But given the tire sizes, you should be OK with factory sizes. What may be possible is that one end (likely the end with the M&S tires is causing a VDC trigger due to difference in grip F-R.
And before you say/ask, VDC does NOT completely shut off when you switch it off. Maybe 70% cutoff or somesuch number.
Old Aug 30, 2019 | 05:16 PM
Byoungz's Avatar
Byoungz
I understand it doesn't shut down completley. The driver side front is a little lower tread than the passenger front. I am running with Hotchkis adjustible sway bars. After changing front tires any suggestions on sway bar settings?
Old Aug 30, 2019 | 05:32 PM
Byoungz's Avatar
Byoungz
What about the possibility of a bad speed sensor?
Old Aug 30, 2019 | 06:31 PM
MicVelo's Avatar
Given the type of tire up front (M&S), I’d say rhat the front is washing out (plowing) so really, if you use sway bar adjustment as the only to overcome the traction delta F/R, you’ll need to bias stiffness to the rear to force rears to reach max slip angle before the fronts (aka slide first).
But this doesn’t address your VDC/anti-lock issue.... matter of fact, you dial in too much oversteer, it’s goung to make matters worse.
Old Aug 30, 2019 | 07:24 PM
dkmura's Avatar
dkmura
Mic is correct- just wanted to confirm that tire diameter wasn't a factor. Sometimes, the easiest solution is the most likely. The next step is to ask if the OP has checked for any codes held in the ABS module?
Old Aug 30, 2019 | 07:25 PM
Byoungz's Avatar
Byoungz
no. I'm changing fronts tires to match rears. Just asking sugestions on sway settings. But, based on your comments it sounds like there are other issuses possible with VDC/anti-lock?
Old Aug 30, 2019 | 07:30 PM
Byoungz's Avatar
Byoungz
dkmura, mechanic said no codes...? What could be there?
Old Aug 31, 2019 | 06:05 AM
dkmura's Avatar
dkmura
Depends on whether your tech can access all ECM/ABS/BCM codes in memory. If the brakes are truly actuating at speed, it usually leaves some type of code in memory. Are you certain it was ABS kicking in and not VDC being triggered? They feel and act quite differentl
Old Aug 31, 2019 | 06:34 AM
Byoungz's Avatar
Byoungz
Feels like front brakes activate. Not feeling any loss of power. Tech said no codes will check with him again on tuesday.
Old Sep 1, 2019 | 09:50 AM
terrasmak's Avatar
Disable to yaw sensor, simple and easy.
Old Sep 1, 2019 | 12:14 PM
Byoungz's Avatar
Byoungz
Thanks everyone for info. Think I'm going to change the front tires first since that's when the issue began. Then do the disconnects if persists. If I remove yaw sensor will that light up dash board?
JP350Z2004
Nov 22, 2015 11:37 AM
rich2342
Jun 29, 2012 08:26 AM
QTB
Oct 10, 2010 01:29 PM
Jgrizzle
Nov 12, 2008 09:12 PM
joseph109783
Dec 21, 2005 05:52 AM
