HFC should u do if you need to replace cats
Old Sep 22, 2019 | 12:44 PM
Dcrunning's Avatar
Dcrunning
Default HFC should u do if you need to replace cats
I have a bad cat or at least that’s what the P0430 code is saying. I tried to reset the code use some CRC cleaner and fresh 93 gas and it came back on. If I need to replace cat should I just go do HFC’s even if i don’t have any other mods besides intake. Does it harm anything to use existing exhaust?
Thanks
Old Sep 22, 2019 | 05:38 PM
jhc's Avatar
jhc
General & Tech Moderator
Thanks
With HFCs you likely will get a CEL, if you're in a smog area, it may not pass w/o no-foulers.
On the other hand, if you're planning other intake/exhaust mods and you have a clogged cat, go for it! BTW you need a OBDII scanner to delete codes. Gl!
Old Sep 22, 2019 | 09:27 PM
DarkZ03's Avatar
DarkZ03
I've had the Z1 cats for a bit with no codes, might be up for sale in a month or so lol.
Old Sep 23, 2019 | 05:25 AM
OldManZFL's Avatar
OldManZFL
i ran Berk's HFC for 10 years without issue. No CEL, no cracking, no clogged filters, no failing period, great quality
Old Sep 24, 2019 | 05:48 PM
rustyschopshop's Avatar
rustyschopshop
Keep this in mind, if you have an issue with your cats being clogged or shattered it is due to running condition of the engine. Clogged cats most of the time is due to the engine running too rich either from needing a tune up or weak fuel pump. Shattered or melted cats is due to a lean condition which most commonly comes from Vacuum leak. Of course the are not all the cause but the most common. If the engine is running correctly the cats can last a very long time.
Make sure you diagose the real issue before you install a new set that will just fail the same way.
Old Sep 25, 2019 | 12:21 PM
350ZZJoe's Avatar
350ZZJoe
x2 ... 8 years now on Berk HFC's and not a single issue. Definitely great quality
Old Sep 25, 2019 | 12:29 PM
masterjr33's Avatar
masterjr33
running ISR resonated test pipes with their CEL blockers.
works great. sounds great. no codes. and the resonated par tlooks like a cat..
Dewy
North West
Jan 3, 2011 12:20 AM
mvisit1
May 31, 2010 08:09 PM
singh
May 1, 2009 02:29 PM
03aeroZ
Oct 30, 2008 05:26 PM
Mazinger Z
Dec 11, 2006 06:03 AM
