Low trap speed in 1/4mile!!!
Old Nov 18, 2019 | 11:53 PM
813_350Z's Avatar
813_350Z
Originally Posted by SonnyWu
TransGo for sure. And while you at it put in the paddle shift kit too.
Transgo Valve Body Upgrade and Exedy Technics Sports Clutch Kit with the steel mating plates.
Made a world of difference in my 5AT
Old Nov 19, 2019 | 05:50 AM
iideadeyeii's Avatar
iideadeyeii
Originally Posted by Freudenthaler
What’s your set up? Those are some impressive #’s
Originally Posted by DarkZ03
Either his numbers are a typo or he has boost/bottle. Torque is too high for NA.
Ya, I'm boosted peak torque at around 3500 (5psi spring), but even with that I'm only 8mph more than op.
I wouldn't worry about trap speed. Worry about ET and 60'
Side note. Did you ever go to the track before you lowered the gears? If not, seems silly that you would change them without knowing what iit did previously.
Old Nov 19, 2019 | 02:14 PM
Freudenthaler's Avatar
Freudenthaler
Yes and the swap of gears dropped my time by 0.2
Old Nov 20, 2019 | 05:20 AM
bboypuertoroc's Avatar
bboypuertoroc
Originally Posted by jhc
The torque band for the VQ35 tops out at 6200rpm. A stock engine literally has no more power to give after that regardless of gears.
This. I was running that quick/faster with just a plenum spacer and intake.
Old Nov 20, 2019 | 05:38 AM
i8acobra's Avatar
i8acobra
There are a lot of folks out there that don't really understand the relationship between ET, trap speed and traction off the line. My full bolt-on '06 stick would run low 14's @ 105 if I spun off the line and 13.7 @ 99 if I hooked. I low ET with a low mph just means you're launching hard with little wheelspin. What matters is your ET, not your mph. BTW, this is in Vegas with a 7k foot DA and zero track prep. Just to give you an idea how horrible our track is, I had the quickest NA Z in Vegas until the 370 came out.
Old Nov 21, 2019 | 03:27 AM
tcode's Avatar
tcode
My roadster doing 141 mph trap speed and I think it is (s)low.
Old Nov 21, 2019 | 08:47 AM
bealljk's Avatar
bealljk
wanna feel like a loser:
wanna feel like a winner:
477hp/467tq, high 11s low 12s @ 117mph (at altitude) … one more reason NOT to move to Colorado
Pholicious
Tuning
47
Jun 10, 2013 01:49 PM
kevin06v2
Tuning
Jun 18, 2011 01:56 PM
Jairen
Tuning
19
Feb 26, 2010 11:01 AM
04treefiddy
Drag
17
Mar 19, 2007 06:11 PM
feiji
Drag
Dec 14, 2006 08:51 PM
