Oil Light Pops On
Old 08-20-2020, 11:39 AM
Bak3rme
Bak3rme's Avatar
Originally Posted by Tom B517
Just an update for everyone: Changed PCV valve and did another oil change after 550 miles. I was able to pull 2 and a half quarts out this time instead of 1.2. I am wondering if anyone has any idea what the issue is before I tear down and rebuild the motor or buy a low mileage used one? Thank you for the help everyone.
Ur username would have been complete if you changed the 5 to a 6....last year.
But as a check, your are not leaking anywhere underneath? Good to check if there are any wet spots around the engine? Common areas would be valve covers, front/rear main seals, camshaft sensor, spark plug #6. almost 3 quarts gone in 550 miles is pretty tough. I'm not saying that you'll recover anymore than a full quart in these areas but good to see if you are leaking.
Old 08-21-2020, 11:15 AM
Tom B517
Tom B517's Avatar
There are no wet spots anywhere. Pulled the spark plugs and it's dry in there so the motor is burning it plus the mix of it coming out of the tailpipes. Was hoping there would be a fix that didn't involve replacing/rebuilding the motor
Old 08-21-2020, 11:49 AM
Bak3rme
Bak3rme's Avatar
man! I've seen some VQ35DE motors for sale on FB marketplace around MA.
Old 08-21-2020, 01:23 PM
Tom B517
Tom B517's Avatar
Mines an 06 I need the Rev-Up unfortunately
Bak3rme (08-23-2020)
Old 08-24-2020, 03:45 PM
icer5160
icer5160's Avatar
Hey Tom,
It's either your valve stem seals or piston rings or both. Before pulling the engine, get a leak down test done at a reputable shop in conjunction with a compression test. The results should allow you to determine the main issue(s).
Good Luck!
-Icer
M3ANMACHINE
03-11-2009 09:31 PM
Flipstyle
07-31-2008 07:53 PM
Das350z
07-23-2007 07:10 AM
tripmachine
11-10-2005 08:27 AM
Reggi914
06-12-2004 03:33 PM
Quick Reply: Oil Light Pops On
