Pulling the motor
Old Jul 16, 2020 | 11:36 AM
Marchog's Avatar
Marchog
Default Pulling the motor
Just an fwi to anyone who decides to take on pulling the motor themselves you dont have to disconnect the entire wiring harness from the motor whenever pulling it there are 3 electrical clips on the inside underneath the passenger side dash and then the alternator and starter directly connect to the battery with their own wire then 2 chassis grounds one on the passenger side frame rail the other on the front driver side and then the cat O2 sensors. Once those are all removed you should be good to go wiring harness wise if pulling the tranny and motor at the same time.
Old Jul 16, 2020 | 04:03 PM
dkmura's Avatar
dkmura
General & DIY Moderator
The problem for many is the reason they are pulling their VQs in the first place. Serious damage to the short block or heads still require removal of the wiring harness (and ancillary equipment) to easily access components. Disassembly of the front of the Z (bumper, radiator and hood) make pulling the engine/tranny much easier.
Old Jul 16, 2020 | 04:33 PM
bealljk's Avatar
bealljk
Disconnecting the wire harness is just about the least of my concerns when I pull my engine out...
Old Jul 17, 2020 | 08:18 AM
Marchog's Avatar
Marchog
Can you even get the engine out the top without pulling the radiator support? I would imagine if it's possible it would be much harder. I just pulled mine due to good ole fashion rod knock.
Old Jul 17, 2020 | 10:54 AM
RENFRO's Avatar
RENFRO
I'm about to tackle pulling my motor as well. Is there a walkthrough DIY on here anywhere? I plan to do some hunting. My intent is to pull core support and hood off. Not sure if I should or shouldn't pull with the trans attached or not. I figure it might be easier to deal with to pull it all in one go.
Old Jul 17, 2020 | 03:01 PM
Painterguy39's Avatar
Painterguy39
I am installing Z1 poly motor mounts,have to lift the engine about 2 inches,looks like i have to disconnect a/c lines from the clips on the inner fender.I have no intake,fuel,headers or transmission currently installed.Am i missing anything?I will be using a hoist.
Old Jul 19, 2020 | 06:37 AM
Kevin Skene's Avatar
Kevin Skene
Thanks for the tips my dude. Definitely good to know!
Old Jul 19, 2020 | 08:28 AM
Marchog's Avatar
Marchog
I would double check to make sure the coolant hoses powersteering hoses any vacuum hoses the chassis ground points (all I can think of off the top of my head) to make sure that they got enough slack to be pulled up that far
Old Jul 19, 2020 | 08:32 AM
Marchog's Avatar
Marchog
Im sure there is I dont have any saved atm. If you are dropping the motor on the ground i would recommend removing the crank sensor to help prevent it from getting damaged and there are two lines one for powersteering the other idk below the motor and trans that you have to be careful not to hit I personally put a towel over the lines to hopefully help with a blow if one ever occurred(which didnt happen)
Old Jul 26, 2020 | 02:16 PM
Painterguy39
For sure i will,i wont be lifting this thing 1mm until i know there is nothing going to be damaged...thank you
Old Jul 26, 2020 | 04:12 PM
terrasmak's Avatar
I might have lifter the engine 1/2 inch to install mine
Mathe4don
Sep 9, 2018 10:16 PM
Chebosto
Feb 20, 2007 04:16 PM
redline350ZZ
Nov 20, 2006 10:42 AM
