Engine Swap my 350z
Old Oct 15, 2020 | 08:16 AM
SMCM24's Avatar
SMCM24
Originally Posted by iideadeyeii
Turbo stock motor, if it blows get a built IPP /end thread
Yeah ... no. not wasting my time to just blow my motor. Just going to go ahead and do a 1jz swap thanks for the input
Old Oct 15, 2020 | 08:52 AM
iideadeyeii's Avatar
iideadeyeii
We'll hold you to that.
Much easier to swap a built vq35 than a 1jz and much cheaper.
Old Oct 15, 2020 | 09:27 AM
SMCM24's Avatar
SMCM24
Anyone else know exactly what else I would need? Also I wanted something more unique compared to the VQ.
Old Oct 15, 2020 | 11:47 AM
bealljk's Avatar
bealljk
It's gonna be a long, frustrating, and expensive road (with no guarantees) if you don't know what youre doing.
There are dozens of active members on this board who can help you with a built engine / turbo setup / supercharger setup.
There are only 5 or 6 members in the past 10years that have JZ swapped a Z and maybe one is still mildly active.
With that being said, start a build thread to document your progress and we'll help you out as much as we can.
Old Oct 15, 2020 | 03:48 PM
DarkZ03's Avatar
DarkZ03
If you wanted something other than a VQ why did you get a Z? Sounds a bit childish, no offense, and a built VQ will be better than the stock swap you will most likely do. It also will not live up to the desire of a "mini GTR ", at least get a RB26 if you must swap....SMH.
Old Oct 17, 2020 | 06:28 AM
RENFRO's Avatar
RENFRO
Honestly sounds like you're way in over your head. I'm in the middle of pulling my VQ for a build and turbo. It's a lot. Plenty of work and cost to do it right, but significantly easier to deal with vs an entire motor swap.
If you're going to do it, do a 2JZ or RB. Royalty Performance has RB swap mounts for the 350 now I believe. Might be worth checking out.
Old Oct 24, 2020 | 10:20 AM
SMCM24's Avatar
SMCM24
Yeah I appreciate that. Really still up in the air. Working with a company by me that has done the swap before. Only reason I would like to go 1jz is because after surpassing 400hp on a VQ, it becomes unreliable. However open minded to what adjustments may need to be made. a built DE may be the easier route as some of the comments expressed. Which does interest me. I deffinetly plan to replace the trans/ clutch etc. anyways. Still a lot to think about.
Thanks to you other guys/girls for the comments. Dope we all can come together during these times and discuss the **** we love
Old Oct 24, 2020 | 01:55 PM
zwei_the_c's Avatar
zwei_the_c
Regular
5 Year Member
I saw a VR38DETT for sale online for $10K USD...
Old Oct 26, 2020 | 06:47 AM
RENFRO's Avatar
RENFRO
I'm not sure where the 400hp unreliable threshold narrative came from, but I believe it to be antiquated and based on old information. The issues I've primarily seen are related to tuning, driving style, and the way torque is introduced into the engine. I have seen several 450-500whp builds on stock blocks that have lasted a long time. Supporting mods, driving reasonably (i.e. not hammering off the redline all the time), and strong tuning go a long way. A basic Vortech setup with some additional mods should safely get you there.
When/if you want to build, a basic/moderate build plus boost should get you to the 550whp range with proper supporting mods on a VQ. I still think it's a cheaper route than going for a full engine swap in the long run.
Old Oct 26, 2020 | 07:34 AM
bealljk's Avatar
bealljk
I think it's been regurgitated year after year … I think the engines hold 400 ft-lbs of torque safely and that equates to 450hp.
Old Oct 26, 2020 | 10:19 AM
iideadeyeii
I'm running roughly 410tq(crank) on a stock 03 block with 145k miles at around 3500rpm and I would trust this for another 50k miles.
This is a dreamer thread and will never happen.
Kspinazzola
Apr 28, 2025 11:52 AM
BabyZ33
May 3, 2019 02:20 PM
DEVRma
Engine Swaps
34
Sep 10, 2016 06:30 AM
xsi3rr4x
Sep 5, 2013 08:21 PM
AgentReaver
Aug 8, 2009 04:19 PM
