N/A Options Almost Exhausted; Time for Cams and/or Supercharger?
Old Apr 14, 2021 | 07:01 PM
350ZXLR's Avatar
350ZXLR
Tou, another option open to you is a higher ratio on your differential "final gear". This will give the car more wheel torque, which means higher acceleration. This mod trades drive axle speed for torque, straight out of the power equation: Power = Torque X RPM. Unless you have a place to stroke the car out to 155mph, all that top-end speed is going unused. If you do have a place to buzz along at 140+ mph, I'm very jealous!
With a high-ratio final gear, you'll be extremely quick off the line. A tire change might be in order to help the rear wheels stay stuck. You'll need to refine your shifting reflexes to match, too, since you'll hit redline quickly in 1st and 2nd. A spring adjustment for more weight transfer to the rear wheels would help, but at the expense of power-on understeer in corners. This is why car setup provides endless entertainment: so many ways to balance and tweak. What works for straight-line performance stinks for road racing. If you do multiple activities, there are lots of excuses to get your hands dirty.
Old Apr 14, 2021 | 07:06 PM
350ZXLR's Avatar
350ZXLR
i8acobra's cam is for a Rev-Up and has 11.4mm lift at 262deg duration. JimWolfe website says 18-24 HP gain after engine tuning, so add another $400 or so for tuning.
Since it's a Rev-Up, some HP gain is due to the variable timing on the exhaust cam. I have a VQ35DE, same as the OP. Variable intake timing only.
Old Apr 14, 2021 | 08:40 PM
DarkZ03's Avatar
DarkZ03
The DE and revup won't be far off, if you already have uprev it could cost $400, if you don't it's gonna be closer to a grand.
Old Apr 16, 2021 | 02:48 PM
mybabyz000ms88's Avatar
mybabyz000ms88
Originally Posted by DarkZ03
I wanted to get the GTs myself but then I fell in love with my current wheels. Heavier and slightly cheaper, but not by much. I got a quote on both and the difference was less than $500, what ultimately drove me to get the Work wheels was the ability to order the offset and style I want as opposed to over the shelf choices.
There's nothing better than falling in love with your wheels my friend. These are the most underrated element of every car.
PrimeX
Tuning
20
Oct 25, 2011 04:26 PM
alfhasg35
Tuning
20
Sep 3, 2010 08:00 AM
DJADL
Tuning
22
Feb 6, 2010 03:37 PM
King350Z
Tuning
61
Sep 1, 2009 12:03 PM
ssnake86
Oct 9, 2007 06:40 PM
