Cats & EVAP not ready? Why?
Old Sep 29, 2021 | 12:10 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
Default Cats & EVAP not ready? Why?
07 350Z.
Went for emissions and cats & EVAP monitors are not ready
I passed once already with this car two rears ago. The only thing that has changed is a tune by Moncef at AdminTuning.
I have driven thousands of miles since having the battery cable off last. Including a road trip. I tried to do the "drive cycle" this morning but no dice.
​​​​​Little background info: I never let my car fully warm up to temp before driving. Is this preventing the cat monitor from completing? I did it this morning but nothing changed
I never cruise in this car. It's driven in the city or spiritedly on the highway. If I do cruise I use CC. Do I really need to try to drive between 53-56 for six minutes straight? That's nearly impossible where I live unless I take an hour and a half road trip outside the city.
Any suggestions? Does anyone know the right drive cycles for these two tests? Thanks in advance. All advice will be appreciated.
Old Sep 29, 2021 | 04:08 PM
Ponyryd's Avatar
Ponyryd
Most likely the tune shut off the cat and evap monitors, did the tuner know you needed e-test?
As far as the monitors, I believe the evap needs a cold start followed by a city run, then a highway run, then a city run. Cat needs a highway run with decel on engine, and mild accel then cruise for a couple minutes. Don’t quote me on that because it’s been a while since I’ve done them, but a drive to my house and back (20min each way, mixed) after a cold start usually got both monitors to pass
Old Sep 30, 2021 | 03:57 AM
zwei_the_c's Avatar
zwei_the_c
Regular
5 Year Member
The tune is the issue. You need to contact Moncef or pay a guy under the table to pass.
Old Sep 30, 2021 | 05:20 AM
seymore4's Avatar
seymore4
Professional
There's your problem right there
Old Sep 30, 2021 | 01:15 PM
DarkZ03's Avatar
DarkZ03
Does the tune shut off the monitors?
Old Sep 30, 2021 | 02:51 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
I received an email back from Moncef. He did shut them off. He sent me a file to upload to the car. Said this should let me ready the monitors.
carson310
Dec 11, 2014 11:29 AM
akbayati1287
Northern California
19
Oct 20, 2011 05:31 PM
Eric the Ricer
Mid-Atlantic
36
May 23, 2008 12:11 AM
mmorris
Australia/New Zealand
15
May 20, 2004 08:06 PM
KONVERTER
Southern California
15
Aug 16, 2003 11:10 PM
