View Poll Results: Will it fit/work
Yes
100.00%
No
0%
Voters: 1. You may not vote on this poll
Rim and tire sizes
Old Sep 13, 2022 | 11:40 PM
Rapto6's Avatar
Rapto6
Default Rim and tire sizes
I’m new to the car scene really and I was looking for some new rims I found a steal on some 18x9 with a 30 mm offset. But they come with tires that are 255/45 was wondering if it’s possible to run these and if so can they be ran all around? If not what would you guys recommend. Looking to run 245/40/18 in the front and 265 in the back not sure what rims would work for those sizes.
Old Sep 14, 2022 | 02:00 AM
travlee's Avatar
travlee
Master
they will be sunken in looking.
i personally ran 18x9.5 +23 with a 255/40/18 in the front, and 18x9.5+15 with a 275/40/18 in the rear (alot on here also ran 18x10.5+15 with 27540/18 in rear)
Old Sep 14, 2022 | 02:54 AM
KoroZensei's Avatar
KoroZensei
Default I agree travlee
I Agree while some spacers will fix that look I still would recommend going with proper fitment.
There is ALOT more room on a Z than you realize. Personally I am running 19X8.5+20 265/35 front and 19X9.5+20 285/35 rear with stock suspension. I know that is a little excessive but I also see that there is still more room in the wheel well.
Fitment>Spacers
Old Sep 14, 2022 | 07:09 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
What Travlee said. ^^
Those are perfect 18" sizes. Matches stock 225/245-45 diameters so no issues with VDC/TCS if you have either.
FTR: 255/45 are way too tall. Like an inch too much. Unless you like the rally car look.
If you go +15 rear, be prepared to roll n' seal the rear fender lips (especially if lowered.) I've run about two dozen sets of wheels/tires on my Z cars in everything from +30/+33 (OE sizes) down to +8 (current). It was only when I put on a set of 9.5 +15s that I needed to roll the lips. Ever so slight tire bump on speed bumps and driveways. And I'm only dropped 19mm.
Note: If you go to 35 series tires as was noted in post above, make sure you do it F&R to keep the tires properly staggered; again, if you have VDC/TCS as mismatched diameters can trigger your traction systems. Not always but just to be safe. The same 255/275 but in 35 aspect ratio will be shorter than stock by a whole inch so I don't generally recommend 35s unless you're dropped a fair bit. If you're not lowered, stick with 40s as it helps to keep the fender gaps same as stock.
Old Sep 14, 2022 | 07:58 AM
Rapto6's Avatar
Rapto6
Fitment>Spacers
okay so what abt a rim that’s 18 x10.5 with a 20
mm offset would I be able to run 245 in the front and 265 in the rear with these rims?
Old Sep 14, 2022 | 08:35 AM
travlee's Avatar
travlee
Master
i wouldnt do a 10.5 in the front
travlee's Avatar
travlee
Master
if you want to run "square" wheels, do 9.5
Old Sep 14, 2022 | 08:51 AM
Rapto6's Avatar
Rapto6
why shouldn’t I?
Old Sep 14, 2022 | 09:28 AM
travlee's Avatar
travlee
Master
wont fit without a ton of camber
look at my pic, that was 18x9.5+23 and it rubbed on the fender liner screw
Old Sep 14, 2022 | 09:32 AM
travlee's Avatar
travlee
Master
unless you want to look like one of these "special" people, then tya
Old Sep 14, 2022 | 09:57 AM
Rapto6's Avatar
Rapto6
Hahaha okay cool I appreciate it man😭 so go 9.5 all around?
Old Sep 14, 2022 | 11:02 AM
travlee's Avatar
travlee
Master
if you rub in the front, at the top middle of the fender is a screw, that is usually what it rubs on, i just removed it
DJK
Jan 7, 2009 09:08 PM
tig488
Apr 15, 2005 07:33 PM
o snap its eric
Mar 24, 2004 09:29 AM
GY-Z
Mar 19, 2004 11:02 AM
jabroney12
Feb 24, 2004 06:40 PM
