Rims and tires help!
Old Sep 17, 2022 | 09:01 PM
Rpator623's Avatar
Rpator623
Ggg
Old Sep 17, 2022 | 10:06 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by Rpator623
So currently abt to pull a trigger on some rims I found. They are coming off a 350z and they are 18x8.5. Previous owner had them on a squared set up of 245/45. My question is can I run 265s in the back with this rim size? If not should I make the fronts 225/45? I don’t really want to run a squared set up perfer staggered. Not sure what’s the biggest tire I can put on these rims though. Anyone have suggestions on what I can do with these rims?
On that stock size wheel, I'd put 245/40F 265/40R assuming 8.5 all around. 265 is about at the outside edge of tires that can be run for performance gain on 8.5 wheel. (You can "fit" larger tires but the performance won't be there on a wheel that narrow.)
Old Sep 17, 2022 | 10:26 PM
Rpator623's Avatar
Rpator623
okay for sure I appreciate that so can I keep the two front tires he got on and just replace the rear with 265/45 or should I swap them all out for 245/40 and then The rear 265/40? And yea they are 8.5 all around
Old Sep 18, 2022 | 05:57 AM
MicVelo's Avatar
245/45-18 is too tall of a tire for the front. That's why I recommended 245/40 for the front, which is the same as stock diameter as OE tire. 265/40-18 Rear works. A 275/40 is actually better but almost worthless on an 8.5" wheel.
If you're trying to save money on tires, get a pair of 245/40s for the front and run the 245/45-18 (OE size rears) on the back. But you wanted stagger...
Old Sep 18, 2022 | 09:28 AM
Rpator623's Avatar
Rpator623
i was reading a few other threads and some were saying 245/45 was good and they put 255/45 in the rear. Is this something that could work
Old Sep 18, 2022 | 07:03 PM
MicVelo's Avatar
You seem to want to run 45 aspect tires for some reason. Is there a particular reason why what I've said twice isn't adequate?
Here's the facts...
225 45-18 25.97"
245 45-18 26.68"
245 45-18 26.68"
255 45-18 27.04"
So, work? Yes.
Best solution? No.
Up to you now.
Old Sep 19, 2022 | 10:41 AM
KoroZensei's Avatar
KoroZensei
Default MicVelo is right but...
I agree with this if your budget/performance minded. If you have a little extra money for rubber and want "stance" fitment without the lowering your car problems the 45R18s are the way to go. I run F:265/35R19 the 19in equivalent to 235/45R18 and have about a finger and a half fitment.
Old Sep 19, 2022 | 11:34 AM
iideadeyeii's Avatar
iideadeyeii
https://tiresize.com/calculator/
nohoch
Jun 6, 2014 10:50 AM
1fstmoforacer
Mar 17, 2009 10:13 AM
mirage328
May 21, 2004 11:29 AM
ZintheKeys
Apr 4, 2004 06:48 PM
b3n84
Dec 28, 2003 07:17 PM
