Turn signal problems
Old 01-25-2023, 01:49 AM
tokec
tokec's Avatar
Default Turn signal problems
Long story short I bought out ‘08 Z and the headlights were all busted. I wanted to get it registered and needed to replace the headlights. I bought some Spec-D headlights and put them in but here’s my problem. I put the turn signal on and nothing happens. I turn on the headlights and the DRL leds turn on and then I put the turn signal on and the DRL’s start flashing. Anyone know what the correct wiring should be or how to check that out??
Old 01-25-2023, 04:11 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,096 Likes on 776 Posts
Check out this post I made a while back. It contains both the 6-pin and 8-pin wiring diagrams. The wire colors may be different, but the pin out will be the same. Since you have an 08, the 8-pin diagram will be applicable for you.
https://my350z.com/forum/exterior-an...l#post10994098
As far as the wiring on the spec D lights, you may need to modify it accordingly.
Old 01-25-2023, 07:07 AM
khnitz
khnitz's Avatar
You'll need a wiring diagram to sort this out, and a DVM (volt/ohm meter).
The Factory Service Manual is available for download (the link was recently, kindly, shared again in this post: https://my350z.com/forum/2003-2009-n...l#post11096112 ).
Good luck!
creativename
12-29-2017 07:12 PM
3hree5ive0ero
08-31-2017 03:38 PM
arejohn
06-21-2007 12:21 PM
Long Beach Jim
12-01-2004 03:22 PM
Quick Reply: Turn signal problems
