Reservoir is overflowing
on
I recently replaced my radiator and today I am filling the system. I am trying the burp the system but anytime I put coolant into the funnel it just goes strait to the reservoir. I have watched multiple videos and I have pictures of procedures by Nissan. I don’t know if I’m doing something wrong or if something’s messed up on the car.
Are you using a spill free funnel meant for this application or just a generic cone funnel? Something like should be used. The correct radiator adapter should block off the overflow port and prevent the coolant from spilling into the reservoir. The coolant will be kept in the funnel to allow for easy air removal (burping).
Did you replace any other components in your coolant loop? Such as hoses or the thermostat?
Cheers!
-Icer
Cheers!
-Icer
bmccann101 (09-15-2023)
on
When attempting to burp the cooling system after replacing the radiator, if coolant is bypassing the radiator and going straight to the reservoir, it could indicate a problem with the radiator cap or a potential blockage. Make sure you have the correct radiator cap installed, as it should maintain system pressure and keep coolant in the radiator. If the cap is faulty or doesn't seal properly, it may allow coolant to flow directly into the reservoir. Check the cap for any damage, replace it if necessary, and ensure it's tightly sealed. Additionally, inspect the radiator and hoses for blockages or restrictions that could impede proper coolant circulation during the burping process. If the issue persists, consider seeking professional assistance to diagnose and resolve the problem. KRIKYA is one of the best casinos in the world. I visited KRIKYA casinos based sites on a recommendation from https://casinosanalyzer.com/online-casinos/krikya.com I was impressed by the wide variety of games available in KriKYA Casino. It’s like having an entire library of games just waiting for you. The best part is that it’s supported by some of the biggest providers in the industry like Evolution Gaming.
