View Poll Results: 2007 350z limp mode after clutch job
Multiple Choice Poll. Voters: 2. You may not vote on this poll
LIMP MODE, replaced clutch for a z1 clutch and now stuck in limp mode
i sent my 2007 350z to get whole clutch replaced including flywheel (z1 motorsport clutch with light weight flywheel) when the guy replaced it and try to drive it, it was stuck on limp mode.idles under normal and doesn’t rev over 1,200rmp, and doesn’t accelerate .the car was running fine when i drove it to him(30miles)even with a bad clutch and now he claims he installed everything right and it must be something different.
we tried cleaning throttle body and removed cats and still the same issue,STUCK IN LIMP MODE i tried the ecu reset and idle reset but not working(doesn’t idle over 1k)
i have been looking and it can be many things, only check engine light code that popped up was p0507
i was reading that if flywheel isn’t alligned or installed correctly it can be put into limp mode
HELP PLS
(car was running normal before the whole clutch job just rpm’s would fall when i would accelerate {clutch slipping} don’t know what else to do
HELP PLS
goes into gear but car stalls if i let go of clutch pedal and doesn’t go over 5mph literally clutch needs to be engaged the whole time
idles at 800rpm and when i rev (foot to the floor) the max is 1400-1500rpm
oil gage reads low but before the clutch job it was the same and it reads the same
350Z/370Z Tech Moderator
Interesting how when it rains, it pours (with similar sounding issues with similar sounding fixes).... https://my350z.com/forum/2003-2009-n...th-my-car.html
By the way, for this poll, I vote "limp mode".
michaelsevilla
Jun 5, 2014 01:54 PM
stx
Mar 12, 2004 02:29 AM
