03 350z headlight issue
Old Jan 8, 2024 | 01:16 PM
Bear4297's Avatar
Bear4297
Default 03 350z headlight issue
Recently had a ballest go out on the passenger headlight. Changed the ballast and replaced bulb. Now when my headlights are on ( low or high beam) they start flashing in sequence when I turn my right turn signal on, left turn signal doesn't cause problem. I can't seem to trace the problem down. Any help would be appreciated
Old Jan 8, 2024 | 01:19 PM
Heel Til I Die's Avatar
Heel Til I Die
Sounds like the ground or 12v+ power for the headlight signal is contacting the turn signal ground/power.
Did your 03 come with HID as OEM?
Aftermarket or OEM ballast/bulb replacement?
Old Jan 8, 2024 | 01:24 PM
Bear4297's Avatar
Bear4297
Came with factory hid low beam and halogen high beam. oem ballast and just a replacement d2s bulb from autozone.
Old Jan 8, 2024 | 02:01 PM
Bear4297's Avatar
Bear4297
also the left headlight will blink with right turn signal on but only when high beam are on
Old Jan 9, 2024 | 05:03 AM
Heel Til I Die
Inspect the clips and harnesses at the main connection points to the passenger side headlight. It sounds like maybe some of the wires got pulled out of the harness clip and they are contacting each other. Make sure everything is secure and pushed in all the way with the wire insulation intact and not stripped. Since the problem only occurs with the right turn signal, signs point to that side being the issue.
shyun1250
Apr 20, 2013 12:35 PM
hunterclowdus
Dec 31, 2011 09:17 AM
RussucoBlack350
Oct 29, 2009 07:33 AM
superblackz4me
Jun 21, 2005 04:42 PM
