05 350z not cranking after replacing fuel pump
Old 05-27-2024, 03:33 PM
Coinshop31
Coinshop31's Avatar
Default 05 350z not cranking after replacing fuel pump
Someone plz help. My 350z wasn’t started in 7 years. It just cranked but didn’t start. I replaced the fuel pump which was 100% needed I pulled the old one and was seized. I drained all the gas and vacuumed out the sludge in the tank. Put new gas in. And now the car won’t even crank over. Also replaced the battery and connectors. Also don’t know if this is a separate the soft top doesn’t work. Only 30k miles on the motor. Could I have done something wrong with the pump for the car not to crank? No codes on the reader. Checked nessasry fuses too they look good. Thank s for any help!
Old 05-27-2024, 07:20 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,304 Likes on 904 Posts
Welcome- if the Z won't crank, you likely have a starter issue. I'd start by checking the wiring connections to the battery and starter, including connections and grounds. No telling what kind of installation problems you might have with the fuel pump itself, What kind of fuel pump did you purchase? OEM is usually your best bet.
Old 05-28-2024, 05:22 AM
dkmura
dkmura's Avatar
You might also want to check the NATS security system. After seven years of not running, the chipped key may not be unlocking the system.
Old 05-28-2024, 03:11 PM
Coinshop31
Coinshop31's Avatar
Default Reply.
The fuel pump I bought off Amazon. I’ll look into the starter stuff. Thank you. And the key unlocks everything and when I turn the key the anti theft does go off. Right before we changed the fuel pump we hit it with starting fluid and it ran for like 3 seconds. I really am trying not to take it to the dealer. Thank you for the responses. For only 30k miles 1 owner hopefully won’t be anything to serious.
Old 05-28-2024, 04:01 PM
dkmura
dkmura's Avatar
Sorry to say, I'm on my THIRD fuel pump from Amazon for my '07 Nissan Versa SL HB. Wish I'd have spent more for an OEM pump to begin with! One suggestion is to put a charger on your battery and keep trying to get the pump going to build fuel line pressure. It took me a few days and lots of cranking to get my last cheapo fuel pump to get going...
Old 05-29-2024, 04:15 PM
Coinshop31
Coinshop31's Avatar
I can’t even get the car to crank I turn the key all I hear is the click of the fuel pump. Before I could get the car to crank but I got nothing now
Old 06-17-2024, 07:58 AM
MelissaPeterss
MelissaPeterss's Avatar
MJF100
09-19-2023 02:05 PM
chrisfollosco
07-16-2021 10:47 AM
jcrow
09-07-2017 04:22 PM
erodriguez
07-19-2013 08:59 AM
350ztxn
11-23-2009 10:55 AM
Quick Reply: 05 350z not cranking after replacing fuel pump
