2007 350Z tire sizes
Old Aug 23, 2024 | 10:01 AM
lumper321's Avatar
lumper321
Default 2007 350Z tire sizes
Hi all, new here.
I have an 07" 350z all stock, has 225/45/18 on front and 245/40/18 on the rear. (I think, I might be off on the sidewall, 40/45.)
I know with many wheels you can go a little larger with tire size's, I was wondering if I can go 245/40/18 all around rather than the slightly slimmer tires in the front.
Thanks for any information.
Old Aug 23, 2024 | 11:59 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by lumper321
Hi all, new here.
Depends on the trim level (or more importantly, whether your 33 has TCS or VDC - guessing it does based on the wheels and your existing tire setup. You must maintain that ratio F to R. 245/40 up front is a good upgrade (with zero issues) on stock wheels. For the rear however, you need to either stick with the 245/45 for the height or go to a 265/40 or 275/40 to keep the height. 265 is slightly shorter than stock height but, will fit the OE wheel whereas 275 is a tad large for an 8.5" wheel. But people have done it with no issues, just not exactly optimum.
Old Aug 23, 2024 | 12:50 PM
lumper1's Avatar
lumper1
Thanks for that information.
So, I'm just thinking out loud,
My initial inquiry was to determine if I can use the same size on all 4 wheels to simplify tire buying and rotations.
But, if I can't do that, or even if I can, I did want to consider possibly going another way, just for the looks and a little added grip, going wider on all four tires, using stock wheels, not necessarily the same size front and rear.
Here are a couple scenarios trying to figure out which would make more sense or if either is even possible.
If I went 245/40/18 all around, for simplicity's sake and to be able to rotate tires, I would throw off the speedo a little since stock the rears are 245/45 now, but anything else detrimental to the stance or the cars performance?
The difference is 5 mm so around 3/8"of an inch.
Or what if I upgraded the front to 245/40 and went 275/40 in the rear, this doesn't change the tire rotation issue but would probably look a little better and I'm guessing slightly wider tires means a little grippier on the road?
And this doesn't seem like an issue for the speedo either, correct?
Sorry, just trying to make sure I understand.
Matt
Old Aug 23, 2024 | 03:27 PM
MicVelo's Avatar
Matt
Re-read my earlier post.
If you have any trim other than Base, you have either TCS or VDC (both forms of stability control).
You must maintain the proper stagger F-R, 3% give/take else wheel speed sensors will tell the ECM your back end is sliding and trigger a Slip warning and put you into limp mode.
Rotation.... not something the Z gets. Resign yourself to buying tires.
Old Aug 28, 2024 | 07:46 AM
350Shadow's Avatar
350Shadow
Your rear tire needs to be taller than your front tires to keep your traction control system happy. That said, going 245/40 all around for simplicity's sake will run the risk of throwing different lights on your dash (abs/ VDC/ SLIP) so to avoid that if you're doing 245/ 40 front, stick to the OE 245/45/18 size for the rear. I also would recommend not going wider than a 255 tire for the rear, anything bigger than that on a stock 18x8.5 might look funny.
Old Aug 28, 2024 | 08:09 AM
iideadeyeii's Avatar
iideadeyeii
Ya, 255's on 8.5" would look CRAZY
275's on my 8" wheels
Old Sep 9, 2024 | 09:21 PM
DanielRodriguez's Avatar
DanielRodriguez
Hi all, new here.
Spoiler
Those look beautiful.
BxMyler
Jun 26, 2010 09:23 AM
blinkz
Dec 14, 2009 11:35 PM
ZinFla
Sep 5, 2005 03:12 PM
BobaFettm
Mar 16, 2005 06:59 PM
azaz
Apr 15, 2004 06:03 AM
