A/C compressor not engaging after Best Buy alarm install.
Old Sep 2, 2024 | 08:29 PM
Ryan-350Z's Avatar
Ryan-350Z
Default A/C compressor not engaging after Best Buy alarm install.
Sorry if this isn’t in the right location.
So, I know the A/C uses that stupid A/C power amp box underneath the radio. And they were definitely up in there when installing the alarm. So my guess is they ****ed up something in there.
Most likely used one of the wires for a 12v source or a ground and that’s why it’s not working. I’ve seen other people with this issue after radio installs too.
I know the compressor is good because I ran a direct 12v source to it and it kicked on instantly.
My question is:
Does anyone know precisely which wires to look for that could have been interfered with? I would like to have some sort of an idea before just ripping into it.
I honestly should have just installed it myself but they offered free installation so I figured “they know what they are doing”. Guess not…
Thank You in advance!
EDIT: Also… my outside air temp is reading “ - - - - “
on the multiguage now. I know the A/C box uses the ambient temp sensor too.
So I’m almost 100% certain it’s all related.
Old Sep 3, 2024 | 01:29 AM
travlee's Avatar
travlee
Master
Check the white ribbon cable behind the controls
Old Sep 10, 2024 | 09:31 PM
Ryan-350Z's Avatar
Ryan-350Z
I did check this.
this was the first thing I looked at. It appears fine. And connected securely.
I’m going to have to go through every wire it seems.
ughh
Old Sep 11, 2024 | 06:57 PM
icer5160's Avatar
icer5160
They might have tapped into some wires for the Unified Meter/Amp. That's the computer box that the ribbon cable runs into. There are multiple harness connections on the back side. Many modern stereos require a tap into the VSS wire. Perhaps one of these connections is loose or they messed something up there. That's where I would look next.
Depending on the depth of the install, they could have also messed with wiring around the battery box in the engine bay. For example if you installed an external amplifier. Next to the battery is the IPDM and a lot of wiring for various components.
What was the scope of the install? Just a head unit upgrade? Or did you go full blown speakers, amplifier, cameras, etc...
Cheers!
-Icer
beznyal8r
Oct 25, 2013 11:15 PM
Kid Krylon
May 27, 2010 02:03 PM
georgyo
Jan 1, 2010 02:40 PM
Jgrizzle
Mid-Atlantic
15
Oct 26, 2009 09:05 AM
dsmZ
May 13, 2009 03:05 PM
